Need help Installing the TEIN EDFC on my GS
I just recently got the Tein CS coilover and EDFC. Now my question is there is a green,black,red,and yellow wire. I know the red is 12v pwr, and the black is Ground, and more then likley the yellow is remote but what is the green? If anyone has installed this let me know where about you tapped in the wires and what the green wire does for me and also suggestion on where to install the EDFC without having to cut to much if any of my car up.
Thank you
Justin Falla
One last question when istalling the EDFC part that mount on the top of each shock how tight do you screw them on (Hand tight/wrench) and do you have to set the valve in the top of the shock a certain way before you screw them on (all clockwise or counterclockwise) or will it set it self once installed?
Sorry for so many questions but no directions installing the Coils is a breeze this EDFC deal is going to be a pain to run all the wires!
Thank you
Justin Falla
Ok guys i got the colors figured out Green is illumination i should have known forgot it lit up for a minute. But still if anyone has any ideas or anywers to my other question im open to suggestions. Where is the easiest place to run the wires remove the seats or threw the centerconsole? Also where is the easy place to get threw to the trunk and engine bay need to know that as well.
Thanks
Justin Falla
Thanks
Justin Falla
The One
Re: Need help Installing the TEIN EDFC on my GS
Originally posted by JBFGS300
[B]I just recently got the Tein CS coilover and EDFC. Now my question is there is a green,black,red,and yellow wire. I know the red is 12v pwr, and the black is Ground, and more then likley the yellow is remote but what is the green?
yellow: All time power supply
red: Accessory power supply
green: Illumination power supply
black: Ground
If you don't have the English install instructions, you can download the PDF from their website.
The One
Rear: You can remove the rear seat bottom and squeeze the wires behind the rear seat back. Whether you want to run each wire down each side of the car or both down one side is up to you. I did the both down one side way.
I'm sure there are other suggestions but this is how mine is installed.
BTW, my unit's illumination is wired with the accessory power so it is always lit up. It was just easier and the unit is always visible since it is lit. I'm not sure if this is a good or a bad thing in terms of the unit's light. It is just how mine is wired. Do what is easier/more comfortable for you.\
Good luck.
doodoo
03-29-13 10:13 PM
yoshi
Suspension and Brakes
06-17-05 07:51 AM
