10 mm spacers: where to buy
I need 10mm spacers. Is there anywhere i can buy them for my 98 GS3, i have 20x8.5 inch wheels all the way around with 245/35/20 tires. Will this do anything bad to them? screw up tread? make the tires hit the fender and slice the tires?
I know H&R makes 15mm, but all i really need is 7.5 mm to clear the Supra TT brakes, so i thought 10mm would do.
Any help is greatly appreciated.
Master Thread Closer!!
What's the offset of your wheels? I assume the wheels are normal or low disk....not made to clear your Supra TT brakes. If you can find 10mm spacers for your car ....you will definitely need to replace the studs. I got 5mm for the rear....and my lugs stick out a bit now.
How about welding two 5mm together? Ummm...just a thought.
exclusive matchup
and yes, if you need spacer coz' your wheel is low disk, unless that original offset is way too high to begin with, otherwise adding the 10mm you might rub the fender bad
Any one know where to get wheel studs that are longer. I had to put a 5/16 (8mm) spacer on my front to clear my tt brakes. I went to Napa and all they had were studs that were 4 mm longer than stock with the same thread pitch. I used them ... but I only get like 4 or 5 turns on them. I'd feel safer to get ones that are 8 mm longer than stock to compensate for the spacer.
exclusive matchup
PHML
I'm all over those if he doesn't want them .... stock ones are 40mm ... those look like 50mm ..allmost perfect . Please PM me if he passes
PHML
Pete
EDIT (2/7/04) - Sorry bro....I was told via email that he wants them.
I ran 10mm spacers on my rear for about 6 months with no issues. They were H&R spacers. I bought from a place where I live for a 120 dollars. They come with the spacer and the longer studs. I had the studs change out for about 30 dollars a side.
longer studs
for everyone interestyed in longer wheel studs. I had recently put on a universal 8mm spacer in rear of GS400 to clear caliper for new wheels. due to safety reasons and peace of mind I needed longer studs. I tried to get HR spacer kit but they only make 5 or 15 mm, anything over 10mm will not work on my setup. Our GS400 wheels stud is the exact part on a Toyota Rav4 and according to the parts dept at a dealership all Toyota wheels stud are same specs except the length. Upon further research the Landcruiser stud is about 5-6mm longer in lenght. Tommorrow I am having my rear studs replaced at this shop. The nice thing is these are OEM parts the part # is 90942-02052 and cost me $5.50 per stud. Hope this helps anyone out there.
