Happy Thanksgiving!! Do I have to raise the car to install the TRD STB..Help please..
Updated with pics! Do I have to raise the car to install the TRD STB..Help please..
Just got the STB yesterday, have some time today to install it.
Do I have to raise the car to install it,
- 2ndly, would my suspension warranty be void if I did it myself.
- How much do you guys think the dealer may charge for the install..
Thnak you all, and have a safe thanksgiving..
stb
you're talking about the one in the engine compartment i assume. you can do it yourself with a socket set 3 bolts on each side & no you don't have to jack up car to do it. takes at most 10 min. and i am horrible with mech. things. i would guess a dealer would charge $60-$90. do it yourself it is so easy.
You may have to jack up one side or the other if it doesn't go right on. I've had to do this with mine.
And no, you won't void a warranty with an STB.
The One
OOOKkkk
No luck so far.. Have tried the STB with the car on theground and the brace would not go right on..I also tried raising each end of the car and that didnt work either...
- Do I need to raise the whole front/or the whole car...
- the brace doesnt look like it can just go right on the towers..If one end fits the other is off..
Any suggestions...
Any suggestions...
Don't raise the whole front or back - just one side at the front on the factory jack point. It might then take some 'jiggling' and even a bit of force to get the STB on, but you can do it, trust me. If I can, anyone can.
The klutz.
The klutz.
I
I can try again but I dont think its close enough were I can force it..Dont know what could it be..I will give it a shot again..
_ I still havnt taken the bolts out..Do you think that it would help to loosen or remove the bolts???
Re: I
TRD tower bar installed
At first try last week, mine won't fit either. I called the guy who sold me and he told me that there's no need to jack up the car. Yesterday, there was about 1/4 of an inch miss match to fit both sides completely. What I did was to remove the washer on both sides and then my TRD tower bar sit up there perfectly. Finished in less than 15 minutes. I had the two washers in my garage now sitting on the shelve. Removing the washer is the only way I could have made the TRD tower bar fit perfectly. Any thoughts or effect(?) about me removing the washers? There was in fact noticable improvement. Body lean was gone.
My friend's Camry SE comes with Tower bar as standard, I hope this has nothing to do with voiding warranty.
Here are the pics
You guys were right. once I removed the bolts the STB slid right in place.
- Drove about 3 miles after the install and yes there is a very noticable difference. There is very little roll when moving the steering back and forth. The steering response is much better too.
Very much worth the monbey.
Thanks to Steve at Carson Toyota
Congrats. I still have the plates under my STB. Maybe I'll take 'em off sometime, since they don't seem to add any value (but do add weight).
