redirected drama.
Originally posted by onelasttry
Spy shot's. Thanks Tony for the L. i shot this pic with 2 bulbs out
i think that whole cluster is grose
the emblem is covering up the numbers on the rpm and cluster, its like distracting to the eye.
the cut around the temp and gas isnt all that great, still could see the back.
It looks hard to see at night.
does it give you 10whp?
i dont see any skills when you can open up a cluster, put a red cover on it, and distroy the needles.
how hard is it to replace light bulb condoms with some color ones?
Originally posted by NRG
what are you going to do with your tach and mph needles, they look distroyed.
I vote for a ban
Forum Administrator
i vote ban too
do you really think its easy to ban anyone on a forum? i hope you understand how the internet works.
i vote ban too
Keeper of the light
A. what are you going to do with your tach and mph needles, they look distroyed.
B. i think that whole cluster is grose
C. the emblem is covering up the numbers on the rpm and cluster, its like distracting to the eye.
D. the cut around the temp and gas isnt all that great, still could see the back.
E. It looks hard to see at night.
F. does it give you 10whp?
G. i dont see any skills when you can open up a cluster, put a red cover on it, and distroy the needles.
H. how hard is it to replace light bulb condoms with some color ones?
b.) grose is spelled GROSS
c.) and?
d.) they are snap in pods, i didn't touch them. tell the factory.
e.) it has 130 watts worth of bulbs in it, Ray Charles could see it.
f.) no, 50 at the crank, the blue gives slightly more.
g.) again, distroy ..... typo?
h.) P=IE through a study of luminance of factory bulbs i have searched and determined there must be a higher output bulb installed to radiate the proper lux for it to remain bright enough to see in direct sunlight. after changing 15 sets of bulbs out and countless studies on heat radiation i have picked the proper thickness of caps to withstand the heat, the proper voltage of bulbs to produce the proper luminance and radiate at 99 degrees within the cap and keep the bulb from damage due to high ambient temprature.
High Ambient Temprature.
Most miniature incandescent lamps will operate normally between -55c and +100c. When the glass temperature goes above 100c, moisture, which is entrapped in the crystalline structure of the bulb, begins to evolve into the vacuum of the bulb. This moisture begins to attack the hot tungsten filament, forming tungsten oxide that is deposited on the inside wall of the bulb. Here, moisture is released and goes back to attack the filament again. This is known in the lamp industry as water cycling. The filament becomes weaker, causing early failure and the bulb becomes prematurely black, causing light output to decrease.
Furthering my research, i have spent countless months under a magnifying glass assembling 1.5mm surface mount diodes end to end to create a 135+ long line of smd's and stuck them into a needle with the internal width of a toothpick. Designing them to work in an environment of fluctuating voltage, and balancing them to spec weight on a triple balance digital scale. I have modified the circut from 13.8 volts to 4.5 volts with absolutely no PCB modifications whatsoever. it has been designed to go back stock form within 5 minutes.
Balancing the needle's, assembling 135+ smd's, modifying the voltage of the circut without degrading the stock PCB, dremeling everything down to the mm under a magnifying glass, modifiying the stock backlighting to higher voltage bulbs through 5 pages of written formula's on heat and voltage to make sure they will work dependably, and doing it for NO PROFIT.
Is THAT the answer you were looking for?
Apparently, some people don't understand the amount of work that you've put in to these clusters. After year's of people complaining and scurrying around trying to find replacement clusters for their SC's because of dead needles, you stepped up. It's given people options to make their SC unique. Aside from a few minor and inconsequential (see, I can use the spell check unlike some people. Hell, I'm drunk and know how to use it) opinions, the overwhelming majority love the new stuff. Good work.
I don't think that everything has to be about HP gains. Aesthetics (check a dictionary) is also the reason we mod cars. Otherwise companies like Volk and Lowenhart would not exist and noone would have sent Onelasttry a cluster to mod.
I wouldn't take the opinion of someone who won't mod their car seriously anyway. Isn't that the reason almost all of us are here?
onelasttry: sorry. i should've read the whole thread first. i thought you were still changing the condoms on the light..
Didnt know you were working on the needles now..
good work.
About your post, i understand everything you said too. I too, love doing electric engraining stuff. I started when i was 10 with small hobbie projects kits. Then in my high school years, i modified consoles like xbox, playstation, ps2, etc. Installing mod chips with only 1mm surface room to work with. I still do it on an occasion if someone needs one done. Now i just concentrate on school and work.
Dave: ill be nice today (yea... right.. )
Vegassc400: Actually people mod their cars because they want their stuff to look good. They care about what others thinks, because they're so unsecured. Only reason why companies exist, because their are people out there that will just buy anything. Thats why i buy name brand crap.
Why do you think alot of generic rice boy brand exist? because not many can afforded big brand products. Modifying cars is very inexpensive now days.
The only reason im here, because i like to be. Im in alot of car forums, ie: honda-tech, club4ag, clubrsx, off-topic.net, etc. Do i have to own that type of car to be in the forum? The only reason im in so many, because i have the knowledge in many cars. Because i grew up with them, working in my dad's shop =
Anyways, continue on
good work.
i vote ban too
i vote ban too
of course its easy any moderator can do it. how do you become a moderator you ask? a little bit of cash a little bit of time...... viola....!
anyways so much for the internet being a median to voice opinions. so someone has negative opinions, gee i guess we'll just have to ban him than. kinda sucks because im not gonna get a chance to see what the reply from the moderators are because ill be banned soon as i can say vrooom....!
where does a car fan have to go to voice himself....... im starting my own forums.... http://www.PREVIOUSLYSUSPENDED.com come join now.....! no self rightous moderators to look down on you. we accept all opinions here not just the ones we feel like hearing......
there my two cents........ ill be back....!!!!!!!!!!!!!!!!!!!!!!!!
Originally posted by whyshoyu
i think ill buy a honda and go on the superhonda.com forums
Forum Administrator
where does a car fan have to go to voice himself....... im starting my own forums.... http://www.lexusclub.com come join now.....! no self rightous moderators to look down on you. we accept all opinions here not just the ones we feel like hearing......
Some suggestions to help you "try". Be a little diplomatic and open-minded, ClubLexus is NOT a Honda forum, we're a Lexus forum and (I hope) a little more upscale than most ricer-focused forums. Use constructive criticism... to say you don't like it is fine, but clearly explain why and what you like better. Don't just drive by and say "that's stupid" or "that's rice" with some accompanying sarcastic comments, especially when you haven't at least taken the time to read the whole thread. NRG, I hope to see you at least try that.
I'm not sure where whyshoyu get's his ideas from how moderators come about. On CL we pick them because of the way they help other members and on their professionalism. They're all volunteers and don't pay in our get anything in return.
