Kenwood SIRIUS H2A Ashtray install (WORK IN PROGRESS)
Old Jun 30, 2003 | 06:26 PM
ceboyd's Avatar
ceboyd
Default Kenwood SIRIUS H2A Ashtray install (WORK IN PROGRESS)
Well, it started tonight --- the new Kenwood Here To Anywhere unit is aobut to become a PERMANENT unit behind my ash tray door. The next task is mounting the newest generation small antenna on the trunk in front of the 3rd brake light and then putting all the pieces together and turning it on.
Here is the first 'work in progress' photo:
Attached Thumbnails Kenwood SIRIUS H2A Ashtray install (WORK IN PROGRESS)-h2a-closeup.jpg
Old Jun 30, 2003 | 06:28 PM
ceboyd's Avatar
ceboyd
and one more view:
Attached Thumbnails Kenwood SIRIUS H2A Ashtray install (WORK IN PROGRESS)-h2a-far-away.jpg
Old Jun 30, 2003 | 06:29 PM
ceboyd's Avatar
ceboyd
..and one more..
I'll post more photos the next time I get more done
Attached Thumbnails Kenwood SIRIUS H2A Ashtray install (WORK IN PROGRESS)-h2a-2.jpg
Old Jun 30, 2003 | 06:47 PM
Phu's Avatar
Phu
Very clean install CE.
Old Jul 1, 2003 | 07:16 AM
dseag2's Avatar
dseag2
Very nice.
I still need to do that with my XM.
Old Jul 1, 2003 | 08:17 AM
Robbo's Avatar
Robbo
I'm very interested in hearing how you get the antenna on the trunk. My installer was completely stymied by the dual hinge trunk and the "fishing reel" cable channels.
Old Jul 1, 2003 | 08:30 AM
ceboyd's Avatar
ceboyd
I'll post the photos when it is done.. but my installer (a 12+ year master tech who works for Infiniti) said he sees how it can work by routing it next to the 3rd brake light wiring. Since the antenna wire is so thin, it should work out well.
..he did mention that it will be a big job and chunks of the car (including the trunk skin) will have to be taken off (and put back on of course) to make it a 100% clean and functional install.
Since I plan on taking a big out west (Chicago - California - Washington - Yellowstone Park - BadLands - Chicago) roadtrip, I wanted to make sure I get the best possible signal strength.
I've been told repeatedly the 'tail' is necessary as well as a metal ground plane of at least 12" round for proper signal strength (and no drop outs) in rural areas where there are no repeaters.
Since my big road trip will entail lots of 'middle of nowhere' driving, It will be a good test of a proper install
Old Jul 1, 2003 | 09:03 AM
dseag2's Avatar
dseag2
You can also attach a Terk antenna magnetically to the driver's rear quarter panel. There are really no wires showing since the rear seat pops out and you can tuck them underneath. My reception is great w/ very few dropouts, no interference in putting the top up/down, and I only remove the antenna when washing the car. Sorry, no close up, but you should get the idea from the attached...
Attached Thumbnails Kenwood SIRIUS H2A Ashtray install (WORK IN PROGRESS)-esm0004.jpg
Old Jul 1, 2003 | 09:17 AM
ceboyd's Avatar
ceboyd
not bad... but even though the standard antenna is on the side fender, I'm a stickler for centering and want it right in the middle of the trunk to get maximum (ground plane) as well as looking good being centered with the third brake light.
I intend to use the magnetic (non permanent) mount (of course) to make it easiest for washing and Zaino applicaiton
I did verify that the trunk is magnetic... apparently, just he folding panels are aluminum but not the trunk.
rcpromo1
Sep 5, 2011 03:18 PM
Lexus88
Jul 5, 2007 02:05 AM
Jace7
Oct 20, 2006 05:38 PM
OneOfOne
Mar 29, 2006 01:23 AM
ceboyd
Aug 10, 2003 12:49 PM
