Has anyone done a "custom" installation of XM Radio on their GX470? I am scheduled to have this done next week and would like to know if I am at risk of voiding my warrenty.
Here is the scoop....
In order to get a clean installation (one that does not look like an after-market add on where the radio is stuck via velcro to the dashboard), the sound shop I am using (Sound Solutions, Chantilly VA) is going to add the XM radio control (Commander Model) in the location where the Seat Heater controls, differential lock and extra 12V plug-in are located (very front of the center floor console). The sound shop will be doing the following custom work...
1) Relocating the 12v plug-in to the oversized square dummy button located on the lower right dash next to the steering column.
2) Relocating the differential lock to the rectagular, regular size dummy button located on the lower left dash next to the steering column.
3) Relocate the Left and Right Seat Heater controls into a custom face plate along with the XM Commander Radio that will be installed in place of the current heaters, 12 Volt plug in and differential lock control center. The face plate will tilt the XM radio at a more upright angle and will be colored to match the plastic greyish trim on the console.
Do you think I will void any warrenty by doing this? I plan to ask my Lexus dealer but would be interested in your opinions....
Should this work not void the warrenty....I would be happy to post pictures of the before and after results if anyone is interested.
I had Innovative Audio (Seattle) put in the Alpine XM in the same place. The head unit is so small (4" x 1.5" or so) that nothing had to be moved, they just drillled a hole in a Lexus cover plate above the seat heater control. The XM display tiilts up for easy reading by driver or pax, control it with the remote so you do not have to reach down to the head unit with fat fingers.
Results are great, never go back to terrestial radio after cruising the empty plains or crowded cities with satellite radio. Coverage in Canadian Rockies was fine too except in the deepest valleys where the look-angle to the satellite was far less than the mountainside.
Thanks for the info. I went ahead and had my XM installed as described above. I will post pictures when I have a chance. And you are right....no going back to terrestrial radio.
Yes, I also used the modulator. I was not about to touch the complex interconnections they use to supply back seat and so on. Modulator is good enough for my old ears, but the range of music styles and lack of commercials more than makes up for some fidelity loss. I like jazz and classics, and neither are available --especially classics-- even in major cities.
Originally posted by dfeldmanmt I had Innovative Audio (Seattle) put in the Alpine XM in the same place. The head unit is so small (4" x 1.5" or so) that nothing had to be moved, they just drillled a hole in a Lexus cover plate above the seat heater control. The XM display tiilts up for easy reading by driver or pax, control it with the remote so you do not have to reach down to the head unit with fat fingers.
DON
I am thinking about doing the same. Mind if I ask you how much Innovative Audio charged you? I am also in the Seattle area. Care to share a pic or two?
Innovative charges around $1000 for equipment and install. They are a class act, after spending 50K on the machine I felt they were good value for money.
I cannot find the handle to insert a couple of pics, so trying to atttach them. The antenna lead goes under the headliner and down the door post. Control head has a small hole drilled in the plastic pannel behind it for the cable bundle. Restoring the car to as built only requires this panel to be replaced.
It sounds fine, as good as any FM station and hard to distinguish from CD sources.
All digital signals are converted to analog before being selected and amplified. So that is not a factor.
An FM modulator has somewhat less dynamic range than the analog signal from the CD player, audio bandwidth s about the same , you have to have experienced audio ears to hear the difference.
