Run Flat Tires
Old 03-27-17, 09:19 AM
xlr8drR
xlr8drR's Avatar
Default Run Flat Tires
hi all, need your input on these tires. I never had run Flats tires before and was thinking of getting new set of wheels, but tire place i've been going to told me that run flat tires are no good and that I don't need to pay extra bucks for em on the new set of wheels. Also It seems that ride quality on run flats seems more rough compared to regular, or maybe thats just me lol. Anyways, what kinda worries me of course is that the RCF doesn't come with spare, and going on road trips I'm sure there are areas where there's totally no signal for cell and even the s.o.s. So should i opt for another set of run flats on the new wheels?
any advise if appreciated, tnx
Old 03-27-17, 09:43 AM
Deanrcf
Deanrcf's Avatar
The RCF can be ordered with a spare. I have one. It creates a nice hump in the trunk. You can probably order the spare and new trunk cover from the dealership. To be honest, I removed the spare from my trunk, because it weights 50lbs. I'm always in the metropolitan area of San Diego, so roadside assistance won't be a problem. I figure if I can make it home, I'll put the spare on. Can't blame you for risking not having a spare on long trips.
Old 03-27-17, 09:59 AM
GetUrWheel
Former Sponsor
GetUrWheel's Avatar
Run flats are only made just enough for you to slow down safely and crawl to a safe place.. in the end.. a flat is a flat unfortunately... I've also seen run flats damage wheels before because the extra sidewall protection from the tires transferred the force of a ninja pothole hit to the wheels and so you're down a $400+ wheel over a $300+ run flat tire.
Old 03-27-17, 10:23 AM
gs400998
gs400998's Avatar
I ordered a 255/35/19 tire/rim online. That's my spare in case I get a flat.
Old 03-27-17, 10:25 AM
xlr8drR
xlr8drR's Avatar
cool, so i can probably lean towards regular then (vs. run flats) and just maybe add the spare when i do go on trips.
btw, can 20x11s fit the rear for rcf? its still stock right now, but maybe in few months i might look into lowering the suspension.
Old 03-27-17, 10:35 AM
GetUrWheel
Former Sponsor
GetUrWheel's Avatar
20x11 will fit in the rear with 305/30/20 will fit but definitely aggressive.
Old 03-27-17, 11:52 AM
flowrider
flowrider's Avatar
Received 1,949 Likes on 1,372 Posts
This guy did it on a GSF. The wheel specs, which you have not mentioned are in post #26 on page two of the thread. Can't really make a determination of fitment without the specs.
https://www.clublexus.com/forums/gs-...30-20-pss.html
Lou
Old 03-30-17, 12:09 AM
isfvss
isfvss's Avatar
Run flat = noisy expensive stiff ride don't bother
Old 03-30-17, 08:38 AM
EGLIDE
EGLIDE's Avatar
gs400998,
Have you tried to put the wheel on your RCF?
Any clearance issues with the wheel and brake calipers or anything else?
What is the offset on the spare?
Where did you order the wheel and tire from?
i have one of the early released 2015 models and have casually been looking for a spare for the same reasons others have mentioned.
Thank you.
Tpcorr
ES - 5th Gen (2007-2012)
16
05-21-13 10:26 AM
dingo
11-02-09 09:57 AM
kreativ
Maintenance
18
05-25-06 11:03 AM
RDavis0921
06-29-03 05:37 PM
silversc430
10-21-01 07:27 PM
Quick Reply: Run Flat Tires
