Wheel size help
03-26-17, 05:10 PM
Wheel size help
03-26-17, 08:00 PM
if inset means offset, then 24 is too low for both front and rear without modifciation
03-28-17, 02:39 AM
Quote:
Originally Posted by
Twidge
Agreed as I know mine is 35+ for the front and I rub a little so pretty sure you would require some modification.
03-29-17, 06:30 PM
bigblack06
are you running a 245 up front?
03-29-17, 08:47 PM
+24 won't fit. I'm on 20x9 +35 with 255s and that's the max I'd probably ever go before I'll need to modify the fender.
03-30-17, 04:23 PM
Former Sponsor
20x10+24 is going to be a tough fit. You'll definitely need some 245/35/20 tires and max out your negative camber to get them to not rub so hard
03-31-17, 07:53 PM
GetUrWheel
I've had a plus 32 vossen with a 245/30/20 in the front with no issues and that's with a 9.5 with wheel
03-31-17, 09:52 PM
Srjr209
Not particular sure what look you're trying to go for on your car, but compare the specs with OEM sizing to be able to visualize where these new rims would sit.
goto Rimsntires.com, and use their size comparer to visually see the difference.
04-03-17, 09:16 AM
Former Sponsor
naquin123
yes, thats a good size for the front. OP is attempting to put 20x10 +24 in the rear.
Codyb425
Performance
04-02-18 05:07 PM
laxton
IS - 1st Gen (2001-2005)
01-26-13 11:48 AM
DaSyce
Wheels, Tires & Brakes Forum
03-08-08 07:57 AM
dementia
11-12-07 06:57 AM
vikm
04-03-06 01:53 AM
