No DIY for thermostats replacement?
Old 03-26-17, 11:58 AM
Grumpa72
Grumpa72's Avatar
Default No DIY for thermostats replacement?
2004 Lexus RX330
Lots of posts about coolant but not thermostat replacement or am I not seeing anything in the searches? Also, recognizing that there are many quality aftermarket coolants, does anyone know which comparable one is used by Toyota/Lexus?
Thanks.
grumpa72
grumpa72@gmail.com
Old 03-27-17, 05:41 AM
evident
evident's Avatar
I wouldn't use aftermarket coolant for any toyota or honda.
Old 03-27-17, 06:22 AM
Grumpa72
Grumpa72's Avatar
Recognizing that auto manufacturers don't produce their own coolant, tires, lubricants or oil, there is nothing wrong with using name brand products. My BMW dealer sells oil specific for my car but you can be sure that they don't manufacture it, they just relabeled it. There are at least three or four types of coolant you just have to know what your vehicle uses.
H.O.A.T, and others.
http://www.valvoline.com/our-products/antifreeze-products
https://www.google.com/search?q=types+of+antifreeze&oq=types+of+antifreeze&aqs=chrome..69i57j0l3.3173j0j4&client=ms-android-att-us&sourceid=chrome-mobile&ie=UTF-8
I guess I answered my own question.😉
Old 03-27-17, 06:39 AM
Lexuswiz
Lexuswiz's Avatar
You can follow the Toyota guides for the 3MZ-FE engines on toyotanation as I couldn't find one myself here for the RX's. The Highlander/Sienna will probably be the closest matches.
But I recall Pentafrost A1 and Zerex Asian works just as well as Toyota Red/Pink.
Old 03-27-17, 09:31 AM
mandyfig
mandyfig's Avatar
How easy is it to replace the thermostat? My Lexus Tech Tech says, not easy.
Old 03-27-17, 10:39 AM
05RX330AWD
05RX330AWD's Avatar
Unlike the old Ford 302's where the thermostat hose- housing stares you in the face when you opened up the hood.
Old 03-27-17, 11:16 AM
Grumpa72
Grumpa72's Avatar
I was looking for the correct engine designation Thank you . There are enough YouTube videos to tell me that this isn't like my old Corvette and "in and out" in 15 minutes. One site says 2-3 hours.
Old 03-27-17, 11:47 AM
05RX330AWD
05RX330AWD's Avatar
Hopefully this will help....
Old 03-27-17, 12:02 PM
Grumpa72
Grumpa72's Avatar
Yep. That is one of the YouTubes that I had seen.
Old 03-27-17, 01:03 PM
Lexuswiz
Lexuswiz's Avatar
Yeah it's nothing like my 4 cylinders, that's 15 minutes in and out. I still need to do this myself, have only been doing the research to see what it takes.
Old 03-27-17, 01:11 PM
fastnoypi
fastnoypi's Avatar
besides using toyota pink... Zerex Asian or Pentosin Pentofrost A1/A4 are compatible and widely used substitutes for coolant meeting Toyota/Lexus specs.
Old 03-27-17, 05:37 PM
JoeInHNL
JoeInHNL's Avatar
The above video is for a RX350 and is not even close for a RX330. The thermostat on the 330 is located on the back (driver's side) of the engine. The thermostat housing is at the end of the inlet pipe that is connected to the lower radiator hose.
Old 03-29-17, 06:59 AM
alchemist
alchemist's Avatar
I changed my thermostat during my timing belt/water pump DIY but I didnt really mention it:
https://www.clublexus.com/forums/rx-...iy-w-pics.html
jdanielca
07-04-19 02:57 AM
Werner05
06-11-16 10:53 AM
mtnman82
11-11-10 09:17 AM
username:
02-12-09 07:11 AM
wlee69
GX - 1st Gen (2004-2009)
02-23-07 08:39 AM
Quick Reply: No DIY for thermostats replacement?
