Xenon to Tri-LED Swap
Old 03-24-17, 11:11 PM
AspireApex
AspireApex's Avatar
Default Xenon to Tri-LED Swap
Has anyone attempted this swap? I just bought a used 2015 RC350 F sport and saw that there were some used headlights for ~$1500 per side. Does the electrical wiring change and/or ballasts that are required? Thanks!
Old 03-25-17, 09:44 AM
rcJten
rcJten's Avatar
There are a number of changes that would need to be made beyond the headlights. The triple beam setup uses an entirely different light ECU, and you would need the RCF front swooshes as well. It's really not worth the $$.
Old 03-25-17, 10:29 AM
ssmoked
ssmoked's Avatar
holy damn that's expensive
Old 03-27-17, 01:46 PM
E46CT
E46CT's Avatar
Received 2,081 Likes on 1,572 Posts
The tri-LED likely also doesn't perform as well as the large HID projector. The IIHS rated the tri-LED as marginal or poor IIRC. very weak distance projection.
Old 03-27-17, 01:53 PM
ssmoked
ssmoked's Avatar
thats completely false. The tri-beams are very bright at night. Even lights up where the fog lights go
blackbond (01-19-23)
Old 03-27-17, 02:08 PM
E46CT
E46CT's Avatar
"The beams are bright at night" doesn't back up your claim. Not even sure what the "lights up where the fog lights go" even means. I have over 15 years in light modding experience, including four full projector conversion/retfrofits using full OE/German/BMW/Lexus high-end equipment. No generic junk. I go full money big names when it comes to headlight conversions. (Just to give you an idea of my background)
Anyway, if you'd like to look at the science...
Distance rating for Lexus RC projector: 103/51m (left/right)
Distance rating for Lexus RC triple-LED: 66/33m (left/right)
The triple beam LED highbeams are also not as good.
Lexus Triple Beam LED Rated: Poor
Source: IIHS
Old 03-27-17, 02:21 PM
ssmoked
ssmoked's Avatar
Source: IIHS
i don't care what your background is. I'm going off actual users experience and not some paper numbers. When my tri-beam on the rcf lights farther and brighter than any of my friends IS OR RC (yes I tried it) on a dark stretch of highway, that equates it being superior.
Old 03-27-17, 02:25 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Guys I think this is a case of agree to disagree and move forward please.
Old 03-27-17, 06:03 PM
SpeedRcr
SpeedRcr's Avatar
Ummm no. I have them. They are amazing.
Old 03-27-17, 07:37 PM
dchar
dchar's Avatar
This was debated on the RX forum too (regular vs. triple beam LED), but it was concluded that Lexus does a terrible job at the factory at aiming their lights which may contribute to the poor ratings. The lights can easily be aimed up.
Old 03-27-17, 07:45 PM
Megafast13
Megafast13's Avatar
The performance of the standard projectors is much better lol. I would never perform this mod especially with the expense and needing different turn signal/DRL.
Old 03-28-17, 02:50 AM
lexusrus
lexusrus's Avatar
I have the triple beam LEDs on my RCF as well. I can tell you without any doubt in total darkness on long stretches of country highways when I over take another car with just my low beams on, my RCF triple beam LEDs cast a very bright light forward as if the other vehicle's lights besides me on my right are not even there. When I approach semi trucks to pass on the left, they move further to the right and often riding the ruffles on the right side of road. When I pass them with my LX570, nothing.
Old 03-28-17, 03:02 AM
lexusrus
lexusrus's Avatar
So I'm really wondering if you are that good? Better than all those "lighting engineers" at Lexus and Toyota HQ? Who do you work for? Yourself? ( Not to say that self employment is not good. Many GREAT MINDS quit their"JOBS" AND WORK FOR THEMSELVES AND BECAME GREAT COMPANIES WE ALL KNOW. But for many who tried only few are successful).
So unless you have concrete credentials to back up your claims, please don't knock on our triple beam LEDs. What degrees do you have? From which school? What design awards have you won? What professional association are you a member of? Have you won any "lighting" competitions? Even for a NON ENGINEER like myself, I can tell the difference when I can see further with this light versus some other lights.
The tests you referred to will need some additional third party validation. Too many other variables at play. For example miss aimed head lights at the factory.
Source: IIHS
Old 03-28-17, 03:26 AM
yardie876
yardie876's Avatar
FWIW, both the single projector and triple beam headlights are LED. I also think it's all about aiming from factory.
Old 03-28-17, 03:09 PM
Davew77
Davew77's Avatar
When I turn on the high beams with my triple LEDs I can see the signs on the road light up as far as the eye can see. Sometimes that's 2-3 miles.... If they are "sub-par" then I don't need the best....
FWIW I have single HID beams in my RX350 and they are no match for the triple LED beams in my RC F. I have had HID beam vehicles for 10 years now. My 2007 350z had them too. None have been quite as bright.
If it's just the aiming of the low beams (which is probably what they using), that can be adjusted very easily. Heck, even the low beams are so bright that people are always flashing their brights at me. I pity the oncoming traffic when I'm driving in the rain. The light reflects off of the wet road and it's almost like my high beams are on.
How can 3 be worse than 1? Whatever helps you sleep at night.
Quick Reply: Xenon to Tri-LED Swap
