Antenna delete
Old 03-24-17, 07:58 PM
Tetsu
Tetsu's Avatar
Question Antenna delete
Just got my SC300 a few weeks ago and dont need the stock radio antenna anymore, anyone know where to get a good plug for it?
Old 03-25-17, 12:08 AM
phphung
phphung's Avatar
Why dont you need it anymore? Did you put in an aux?
Old 03-25-17, 04:44 PM
LEXXIUM
LEXXIUM's Avatar
You don't want to shave it? Id leave it the way it its, any plug you put in there is going to look hideous if it's not an antenna.
but yeah there are no plugs.
Old 03-26-17, 03:45 PM
mrmj2u
mrmj2u's Avatar
I'll be shaving mine using fiberglass inside and outside the hole. I'll be sure to document my process here.
Tetsu (03-27-17)
Old 03-26-17, 03:50 PM
Htony
Htony's Avatar
What will happen when you want to sell it or trade the car in with antenna absent?
Old 03-26-17, 03:56 PM
mrmj2u
mrmj2u's Avatar
Personally, I'm not worried about that. Im modifying my car to suit me, not the next person. Besides, this isn't my daily driver. I will probably install one of the following in the place of the rear trunk mounted retracting whip:
Metra 44-UA200 Universal On Glass Amplified AM/FM Antenna
Old 03-27-17, 02:39 PM
vanish24
vanish24's Avatar
i just got power from the original antenna & stuck that same antenna up inside trunk lid. i left the factory antenna in place in the down position.
Old 03-27-17, 07:48 PM
Tetsu
Tetsu's Avatar
Yep and its just annoying it poking out. Really want to get rid of it.
Old 03-27-17, 07:50 PM
Tetsu
Tetsu's Avatar
So would clipping it off work? or what would i have to do to get rid of it
Old 03-28-17, 08:05 PM
phphung
phphung's Avatar
Did you get the problem of having sound in only one side?
Old 03-29-17, 10:38 PM
Tetsu
Tetsu's Avatar
No never I have an aftermarket head unit and just dont need the stock antenna anymore.. I don't use radio
only aux, and usb.
Old 03-30-17, 05:08 AM
tsmith1315
tsmith1315's Avatar
The mast is hollow, so clipping it can allow water into the trunk. Is it stuck in the up position?
If you do remove it, there are probably a few of us here who would like to take it off your hands.
Old 03-30-17, 07:39 AM
GreenBeast
GreenBeast's Avatar
I was going to do this to my '92 because the antenna is stuck up and no one cares about radio any more because of aftermarket stereos being cheap and easy to install. The only way I could think of doing it right is having a body shop patch in a metal sheet and finishing it good or maybe using fiberglass but the texture of the fiberglass will look different than the texture of the steel fender to the trained eye no matter how good the finish job is. Personally I'd remove it and choke down the price of having a good body shop do it right. That's what I'm going to do at least.
Old 04-05-17, 06:33 PM
Tetsu
Tetsu's Avatar
Thanks for everyones help!!
Old 04-06-17, 09:41 AM
UpInTheLex
UpInTheLex's Avatar
When I was restoring/refinishing my SC400, I cut a piece of sheetmetal to size and welded it into the antenna hole. Then skim coated it body filler and called it a day.
I disliked the factory AM/FM antenna as well. I think it takes away from the clean lines of the car, so I 'shaved' it.
You could potentially 3D print yourself a plug if you didn't want to do a whole ton of body work.
Tetsu (04-09-17)
Quick Reply: Antenna delete
