2009 Bluetooth pairing question
Recently bought a used 2009 Lexus IS250 for my son. We want to connect his phone via blue tooth but it is asking for the pair code...Is there a way to reset the pair code or to find out what that code is so we can connect his phone?
BLUETOOTH TROUBLESHOOTING:
Step one from the car:
How to set-up Bluetooth; Without Navigation:
-Hit the push to talk switch
-Say “Phone set-up”
-Say “pair phone”
-Say “(your name) phone”
-Say “Confirm”
-Car is ready to pair
How to set-up Bluetooth; With Navigation:
From the car:
- Car on/acc mode
- Info
- Telephone
- Settings
- Register phone
- it'll bring up a menu that has a passkey and looks like it's ready to pair
- Pair
**Just to double check that the phone is paired to the car, from info-telephone-settings-select phone. The phone should be in the system now with a little "BT" symbol next to it.
Step two from the phone:
We’ll use an iPhone4 for ex. Go to
- Settings
- General
- Bluetooth
- make sure bluetooth is on (slide on/off)
- Below that is "Devices" or "search device"
- On the phone, select the "hands-free" 2009 below or “Car Multi Media” 2010+ under search device. It should begin paring and prompt you for the passkey. Enter it and select "pair". It may say it's paired but not connected. If this is the case, then select "hands-free" one more time.
________
Other Troubleshoots:
UPDATE YOUR SMARTPHONES:
Make sure your smartphones are turned off every now and then. They are just like a computer and need to be updated. Sometimes if a phone misses an update, the result is the Bluetooth connection unpairing with the car.
With BlackBerry’s, the most common troubleshoot is to remove the battery from the phone, blow on it and turn the phone back on. Yes it’s a PITA because BB takes forever to load, but it typically works. If this doesn't work either, you can try repairing the phone:
MY PHONE HAS BEEN PAIRED BUT NOT WORKING:
If the phone is not working (but already paired), a common troubleshoot is the bluetooth on the phone could be turned off (happens on mine from time to time). Set the phone to discoverable mode and make sure the bluetooth is set to "on". You should see the bluetooth symbol somewhere on the phones top banner.
-Say “Phone set-up”
-Say “pair phone”
-Say “Confirm”
From the car:
- Car on/acc mode
- Info
- Telephone
- Settings
- Register phone
- Pair
- Settings
- General
- Bluetooth
________
Clutchless
RX - 3rd Gen (2010-2015)
10-03-17 01:41 PM
