Coolant Valley Plate Leak
Old 03-22-17, 09:03 AM
gseven
gseven's Avatar
Exclamation Coolant Valley Plate Leak
Does anybody experience coolant valley plate leak for GX460? Dealer told me this is common problem for high mile GX460 engine. I have 2010 GX460 with 93000miles.
Old 03-22-17, 07:00 PM
tecman
tecman's Avatar
98k on my GX with no problem. Never heard of this here. Please let us know the outcome
Old 03-24-17, 01:18 AM
GX4602011
GX4602011's Avatar
A quick google search shows this a problem on the Lexus IS-F with the 2URGSE 5.0 engine. https://www.clublexus.com/forums/is-...ley-plate.html
The GX460 uses the1UR-FE engine, https://en.wikipedia.org/wiki/Toyota_UR_engine but still a UR series engine.
Since the 1UR-FE engine is used extensively in the Tundra, I would expect those owners would have reported this problem on the Tundra forums. I did find this: https://forum.ih8mud.com/threads/coo...-motor.937309/ read post #6
Yona (10-23-18)
Old 08-07-18, 08:49 AM
TheMick
TheMick's Avatar
Well I just got the call from the dealership, I brought my 2010 GX460 in for a radiator leak which was covered under extended warranty. After they pressure tested the coolant system they found another leak from the valley plate gasket. This sits under the air intake manifold between the two cylinder banks (i.e in the "valley"). This is going to be an expensive job and the extended warranty just paid for itself. The dealer did confirm that he has seen this before, but wouldn't comment on how many or what model years.
My 2010 GX460 just hit 71,000 miles, I don't consider that high mileage so I think it has more to do with age then mileage. Maybe the gasket deteriorates with age?
Update:
I think the comments from Jowett on the IH8Mud forum (linked above) are spot on and worth a read.
Seems it is a prevalent problem in all the UR series engines (Tundras, Sequoias, LC200s, IS500s, etc.) and hopefully the new sealant material will fix the issue...
Old 08-07-18, 04:02 PM
Acrad
Acrad's Avatar
Received 3,563 Likes on 2,333 Posts
I haven't heard of anyone else report that leak location before on a 460...or I missed it. Water pumps failures are fairly common though. I had that one myself but it was fixed under the 6/70 factory powertrain warranty.
EDIT: I didn't realize this thread dated back to early 2017. Checked again today on mine and all clear.
Old 10-22-18, 03:20 PM
mdemar4757
mdemar4757's Avatar
Default Me too
Just had “leak from coolant jacket under the intake manifold” on my GX460 with 116k on the odometer. Cost was just under $2000.
Old 10-22-18, 04:32 PM
Acrad
Acrad's Avatar
Some info on 200 series in regards to this issue from a few years back
Old 10-24-18, 08:22 PM
drnls
drnls's Avatar
My wife's '13 has it. Not in a rush to repair as it is a slow leak. Plan on doing it myself.
Old 01-05-19, 10:09 PM
hrod79
hrod79's Avatar
Took my 2012 in for an oil-change this past march. Was told I had this leak. I said no problem, because I had extended warranty. Vehicle was at 106k. Service writer checked and my Extended Warranty expired 3 days prior to bringing the car in... after some conversations with Lexus USA, they covered the leak. I was told somewhere in the range of $900 of labor at Warranty rate.
Acrad (01-06-19)
Old 01-17-19, 07:29 PM
whalley
whalley's Avatar
Previously, I reported a rare rear main seal leak on my 2012 and yesterday I finally pulled the trigger on getting repaired. In the course of fixing it, the mechanic called today and said they also discovered a coolant valley plate leak. Sigh. At least it's 50% cheaper to get it fixed now while they're already doing the other work.
Old 01-17-19, 08:35 PM
whalley
whalley's Avatar
Researching this issue further and what's puzzling is that it's happening across so many different models that don't share parts. It does, however, look like they share a common design element where the seal consists of a metal channel filled with a silicone sealer extruded from a tube, not a preformed gasket or seal. This makes me wonder if the channel design itself is the problem or if the silicone compound was misengineered or faulty.
Old 01-18-19, 08:53 AM
supperfly1
supperfly1's Avatar
Good point. Just probably a pita to DIY and one has to spend $$ to get it fixed. Question is why does it happen to some and not to others when the design element is the same and or compound is the same
Old 01-18-19, 11:25 AM
whalley
whalley's Avatar
I'm not 100% sure but my current guess is that it's the compound going bad after the vehicles reach a certain age/mileage. If that's true, we should start to see an increase in this issue happening as more of these vehicles age and accrue mileage.
Old 01-20-19, 08:11 AM
supperfly1
supperfly1's Avatar
Any reports of this with the 120 series? Must be only on Japan v8 engines. Havent heard anything on the v6, and no TSB for it.
Old 01-20-19, 11:08 AM
Acrad
Acrad's Avatar
The domestic Toyota V8s produced in Alabama can experience it as well. 120s it seems mostly just water pumps but a lot of those issues are probably mitigated with the timing belt replacement. I've seen quite a number of posts about noticing the water pump on 120s beginning to weep at TB service time.
Quick Reply: Coolant Valley Plate Leak
