CD slot cell phone holder
Nope. So far just putting my cell in one of the cupholder holes. Would like a better solution especially for road trips.
I just laid the phone in it and it is sticky enough that it stayed put.
For the price heck I should try it! Thanks!
Here are the two types I have.
this one clips on and works great in my Trans Am because it has small vents.
http://www.ebay.com/itm/122305611052...%3AMEBIDX%3AIT
this is the type I use in the SC430. It works great!
http://www.ebay.com/itm/Car-Magnetic...item41beab2342
Last time I tried the vent holder on my Samsung Note 3 it snapped one of fins on my vent. From mechanical standpoint both CD slot and vent fins are delicate pieces. I don't think they are designed to withstand any weight hanging on to it, not to mention on SC430 the hazard of radio cover crashing into it is going to be a real concern.
never had any issues in any of my cars with the vent magnet.
By "radio cover" I was just referring to the wooden sliding door that would cover the radio panel. Having a CD slot holder would mean it must stay open all the time I imagine. Unless you disable the switch by unplugging it behind the ash tray sooner or later you will hit the button by accident and I wonder if the motor of the sliding door has any sensor to stop it.
Just speaking from my personal experience that I was very happy with the vent magnet holder until it snapped the fin. Then I realized it wasn't designed to handle much weight and to have a $5 piece causing a $$$ damage is just not worth it most of times.
we are using iPhones 5 and 6 and they might be lighter, I push the vent magnet all the way against the vent blades which provides more surface to lean against. Hope that provides a good visual.
when I purchased my SC430, all four of the vents were broken and I replaced them all. The two on the far left and right were a real pain to remove but they all work now! I picked them up from salvage yards on ebay!
I don't like the vent holder, that why I bough the Koomus. It provides the stability and the magnet is strong. You just have to disconnect the cable from the switch (5 minute job). I know I will loose the ability to close the radio door which I do not care. I use my IPhone for the music and if I need to listen to the CD, it's only take thirty seconds to remove the Koomus.
