OEM radiator or aftermarket radiator reliabilty
Old 03-14-17, 10:47 PM
HarrierRX300
HarrierRX300's Avatar
Default OEM radiator or aftermarket radiator reliabilty
Should I save money and get an aftermarket radiator or get an OEM Toyota radiator for a 68,000 2001 RX300 2WD? Debating... recommendations?
Old 03-15-17, 05:57 AM
Drcoffee
Drcoffee's Avatar
I bought a TYC radiator for our RX from Rockauto.com with no complaints. It pays to buy a thicker core when available. It helps with cooling on those really hot days.
Attached Thumbnails OEM radiator or aftermarket radiator reliabilty-img_1731.png
Old 03-15-17, 12:05 PM
aznlapin
aznlapin's Avatar
Exactly what I did. No need for OEM, I went with the APDI/PRO but TYC is the same. The thicker core really does help, as one of my rad fans is broken but I've yet to have any overheating issues.
Old 03-15-17, 05:54 PM
salimshah
salimshah's Avatar
I am curious as to what went wrong with the radiator ... that is if OP wants to share.
Salim
Old 03-23-17, 10:39 PM
HarrierRX300
Attached is a pic... My friend is recommending Denzo... Good choice?
Attached Thumbnails OEM radiator or aftermarket radiator reliabilty-img953962.jpg
Old 03-24-17, 12:19 AM
salimshah
salimshah's Avatar
hmm Denso is OEM supplier.
Salim
Old 03-24-17, 06:18 AM
thomas1
thomas1's Avatar
Denso is available on RockAuto for cheap also. Less than $100.
Old 01-03-23, 06:46 AM
CCColtsicehockey
CCColtsicehockey's Avatar
Looking at both options now as I get to join the club of having the top of my radiator in my 2008 fail. My car had the recall done in 2015 at 130k miles but it is noted in the service history that the fan screws were found to be tight, they replaced the screws anyways and torqued to spec. So I assume then that the radiator was not replaced and this is still the original one. That was almost 8 years ago though. The car currently just rolled over 156k miles now.
Is there any easy way to check besides when I pull it out and finding the part number stamped on it?
I have been reading several threads on the options. Is there any more long-term data out there at this point of people daily driving their cars with the Koyo setup and no longer having the preheat for the trans? I have to say reading about, it is what concerns me the most about going that route. I did just order FBO and a tune from RR on Sunday only to have this happen yesterday. I won't say it gets super cold in NC but it isn't always warm. I like to be able to road trip most of my cars at any time even in the colder months. It is unlikely though this car would see a northern winter road trip. It does split daily duties right now with my CTSV Wagon though.
Old 01-04-23, 05:48 AM
Drcoffee
Drcoffee's Avatar
if it were me, I would get a radiator with the cooler, then add a tranny cooler to the circuit. Heat and dirt are the enemy of all transmissions. To clean it, add a Magnefine filter to the atf cooler line.
Old 01-04-23, 07:27 AM
davidsboss
6th Gear
davidsboss's Avatar
Default Radiator replacement
I replaced the radiator in my Camry with a tyc through Amazon worked great no issues all. Everyone says get one with more rows I would helps more in the summer.
Old 01-04-23, 09:34 AM
salimshah
salimshah's Avatar
My personal experience is RX300 and other Lexus vehicles is that the engine runs hotter and the demand on radiator based cooling is low even in heat of central Texas. I drove without the fan and the needle barely moved from normal when ever the vehicle stopped moving. Extra capacity won't harm you, but is not needed. just my 2c
Salim
KA8
12-04-15 03:25 PM
oldManTan
Performance & Maintenance
07-19-14 12:30 PM
buttercup9
05-25-13 07:47 PM
coolewong
18
09-08-11 10:37 PM
vj3
12-27-10 07:04 AM
Quick Reply: OEM radiator or aftermarket radiator reliabilty
