Convertible top problems
Old 03-04-17, 08:07 PM
LEXZILLA
LEXZILLA's Avatar
Default Convertible top problems
Hey guys I need your help I just purchased a passenger side motor for my sc ( see
picture)
Is there some pictures or a PDF showing how to replace that motor?
Also how can I get the convertible top codes?
Thanks in advance
Old 03-06-17, 10:37 AM
DshngDaryl
DshngDaryl's Avatar
I bet BGW might have the Factory Instructions to replacing the motor.
If not, here are some thoughts....
Do you know if the hinge you bought worked before they took it out? I think you may be better just replacing the entire assembly.
This is how I did it. https://www.clublexus.com/forums/sc4...etty-easy.html
If you decide to just replace the motor, you can just count the number of bolt holes on the new motor and remove those same bolts on the old motor. Since you have the entire hinge, you can use your phone to record how you remove the motor from the hinge. Just lay the hinge in the same position as it would be in your car and start recording. That way, you can always review what you did if something comes up.
As an FYI, you need some thread locker blue for the motor bolts.
Old 03-06-17, 02:34 PM
LEXZILLA
LEXZILLA's Avatar
Thanks but can I replace the motor with out pulling the whole hinge?
i just posted the picture of the hinge to show the location of the motor!!!
i have searched but found nothing
help guys
Old 03-06-17, 05:03 PM
Bgw70
Bgw70's Avatar
help guys
can you remove the motor in the new hinge?
if so, figure out how to do it in your car.
let us know how the first step goes...
or, replace the entire hinge assembly.
Old 03-06-17, 07:11 PM
LEXZILLA
LEXZILLA's Avatar
I don't have the hinge I just have the replacement motor.
i'm asking if I can replace the motor without removing the hinge?
thanks everyone for your responses
Old 03-07-17, 09:09 AM
DshngDaryl
DshngDaryl's Avatar
Yes you can. I did it and remember it was pretty easy. However, I didn't write down the steps.
I think I opened the trunk like normal, and then just undid the wire harnesses and the bolts. I think I was surprised that I had the most trouble with the grounding bolt. (The wire with the ring on the end of it) And I was disappointed because I didn't buy any thread locker.
Old 03-09-17, 07:06 PM
LEXZILLA
LEXZILLA's Avatar
UPDATE:
I took my car to get a check engine and vsc on light diagnosed the mechanic told me what was wrong and cleared the codes
i had already put the top down when I got home the top wouldn't close after pushing the button a bunch oh times the top finally closed I took the car back and had the car scanned for top codes none found .so can the the button on the climate control be going bad?
Old 03-10-17, 03:00 PM
Harold57
Harold57's Avatar
The button could be going bad but I'm thinking that some (all?) of the codes get cleared out when you turn off the car, so they may have been cleared before you got there.
Old 03-12-17, 09:41 AM
DshngDaryl
DshngDaryl's Avatar
You need a Toyota Specific code reader like techstream to read the codes. It is possible they are using a high end but not Toyota specific reader and couldn't see the codes.
What is most helpful is when you hook up techstream and try to run the top through it's cycles. That gives you a play by play of what is happening and will help you find your problem.
Would the top not work after you replaced the bad motor?
Old 03-18-17, 06:05 PM
LEXZILLA
LEXZILLA's Avatar
Update!!!!
i changed the passenger side motor( my thanks to club Lexus members)
buttoned everything back up hit the button and the top did as before whirring noise and then the top went through its paces .
the button on the climate control is kinda shaky and I think that could be the culprit when the top doesn't move.
after pressing the top button a couple of times the top will work!!!!
help guys
thanks in advance
Old 03-19-17, 12:29 PM
Bgw70
Bgw70's Avatar
Update!!!!
help guys
thanks in advance
run down to Walmart and pick up some contact cleaner, then try to spray inside the switch..
Old 03-19-17, 03:54 PM
LEXZILLA
LEXZILLA's Avatar
I'll try that but should the button be loose inside the climate control?
and I'm still trying to figure out the whirring noise in the rear of the car, I just changed the motor and it still (or something)
is still making that noise (see video in my post)
thanks guys
Old 03-20-17, 03:53 PM
Harold57
Harold57's Avatar
When does the whirring occur? Just when the top is supposed to be running? If it occurs all the time, it could be the fan on your amp in the trunk.
Old 03-20-17, 08:31 PM
LEXZILLA
LEXZILLA's Avatar
He's Harold check out the video I put in my post you will hear the noise I hear and see what the top is doing!!!
now the top isn't moving at all unless I press the button a lot of times
Old 03-21-17, 02:35 PM
Harold57
Harold57's Avatar
Where is the post?
Quick Reply: Convertible top problems
