ISF Driver Seat setting not low enough
Old 02-24-17, 05:31 PM
KraziAzn
KraziAzn's Avatar
Default ISF Driver Seat setting not low enough
Hi,
I noticed my 2012 IS-F driver's seat does not sit as low as the passenger's seat. I'm only 5'8 and I find that there is a lack of head room. I have never sat in any other ISF and I was wondering is it normal for the driver's seat to sit higher than the passenger's seat at the lowest setting? Thanks.
Old 02-24-17, 05:50 PM
kzlflash
kzlflash's Avatar
There's an adjustment to lower the seat. Push the bar down if you haven't.
I'm 6'0 and i still have an inch or so at the lowest setting, and I don't lean back much either.
Old 02-24-17, 06:04 PM
newgsman
newgsman's Avatar
Originally Posted by KraziAzn
Hi,
Are you sure you don't have something stuck under the seat preventing it from lower than it should.
Old 02-24-17, 10:00 PM
KraziAzn
KraziAzn's Avatar
Yeah, I was using the side controls on the seat. I want to say I have less than an inch! Which doesn't make sense at all. Okay, definitely something is odd with my seat.
I checked, there was nothing under the seat. So the passenger and driver seat should be at the same level when it is fully adjusted down?
Old 02-24-17, 10:01 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,845 Likes on 2,332 Posts
I'm 6'2" with a 33" inseam. Long in the torso. I fit just fine with the seat fully lowered, and only need to lean back a little to accommodate a helmet at the track.
Old 02-25-17, 03:14 AM
Jz39
Jz39's Avatar
I do wish there was a way to lower the seat more as well (although you may have a different issue). In my Infiniti there was a way to loosen a bolt under the seat and force the seat to go lower than factory setting-that extra inch or so made a world of difference for seating position. Seems as though a lot of current cars have seats that can adjust super low, almost unreasonably low. Sadly ours do not.
Old 02-25-17, 05:13 AM
SoulFreak
SoulFreak's Avatar
I'm the same height as you and have plenty of headroom, even with a helmet. There's definitely something going on. Time to take it in to the dealership. Especially, if you notice the passenger side being able to go lower.
Old 02-25-17, 03:25 PM
KraziAzn
KraziAzn's Avatar
For sure. Going to the dealership and have them check out
s4play
IS F (2008-2014)
121
05-24-20 06:31 PM
almsdriver
IS F (2008-2014)
07-12-17 05:50 PM
jps84
ES - 6th Gen (2013-2018)
04-23-16 03:02 PM
LionelHutz
IS F (2008-2014)
41
07-22-13 10:32 AM
slee18
06-01-12 05:58 PM
Quick Reply: ISF Driver Seat setting not low enough
