New Owner and Question about B Pillar Panels
Hi everyone! Just picked up a new 2017 IS 300 AWD F-Sport in Atomic Silver / Red. This is my second Lexus coming from a RC 350. Very happy with the car! The smaller V6 packs plenty of power (which was a concern coming from the bigger engine).
One thing I dislike about sedans is the piano black b-pillar panels on the side doors because they are so delicate. Even using a microfiber cloth is a toss up as to whether or not fine scratches will appear.
Is there a product / method to removing the hairline scratches that works without using a machine? I have Quixx Scratch Remover which I swear by for removing scratches from paint, but don't want to make the glossy pillar surface any worse. Otherwise, is there a way to remove the panels so that I can wrap them and reapply without breaking them or ruin the car? Thanks for your advice!
Here are some pictures:
Hi and welcome,
that's one nice 2017 IS! Wish we had the 300/350 over here...
As for the b-pillar panels, I feel you... I don't really have a long-term solution regarding the hairline scratches, but perhaps this solution suits you?
http://www.ebay.com/itm/232110630221
Hi and welcome,
I had a section on my driver door that was scratched pretty bad. I started looking for OEM replacements thinking that it was ruined.
In my exhaustive search I found this, it looks like it is just an "applique". I couldn't really figure anything out.
I think it's just a shiny piece of plastic with adhesive on the back side.
Luckily, it polished out perfectly.
If i am not wrong, the precut is just a vinyl film that has already been measured for perfect fitment..? It should be pretty easy either way and save that $35 and get the vinyl and do it yourself.
For comparison, this should be the OEM part mentioned by doodlebug:
http://www.ebay.com/itm/302046701177
if you want to dress up the pillar a bit, instead of wrapping it, slap on some CF
https://www.carid.com/bi/carbon-fibe....html#warranty
Still highlights what the actual OEM part (75756C) will look like
A flawless OEM pillar covered with a protective layer (3M and the like) would be the ultimate solution I guess. Besides, as you rightly pointed out there are various carbon fiber look or stainless trims... flowers anybody?
Source: http://www.arcray.biz/products.html#pillar
To OP:
If you are trying to take out serious scratches on B-pillar panels, hand polishing takes a long, long time without satisfactory resul.
If looking for perfect finish ( i.e., swirl free, no marring in any lighting), go for machine polishing with right tool, a very light compound and some skills would do.
Start with a final finishing pad first. You would see black stuff coming out as the shiny black panels are actually painted without clear coat. They are high quality (!) plastic panels but are scratch-prone. (vs. matte and durable plastic used in some more mainstream vehicles) If you see polishing action is too weak, then go for the next aggressive pad. Note the black paint on B-pillar is very soft and there is no clear coat.
Besides, make sure you mask the surrounding areas but not have the tape adhesive in contact with the soft black strip (made of EPDM) which is part of the stainless door trims. They are extremely sensitive. If you want to polish the A-pillar black panel as well, make sure you mask the protruding areas as machine polisher will wear it out and you may see discoloured area.
For me, B-pillar panel marring is a big concern to me and like what others have said, avoid touching them help a lot. If you don't want to cover them up, at least, do a proper machine polishing to the condition where you can accept. Then apply some ceramic coating with proper and clean MF. Most ceramic coating adds 7-9H hardness which can sustain car wash-induced marring. You may have to deal with water spot stain later though (typical of most ceramic coating)
Don't look for 100% perfect condition (in all lightings) on those B-pillar black panels as you may have to sacrifice too much paint in order to remove a particular faint but visible scratch.
Even when you pick up the new car without dealership car wash, some scratches and marring were already there on B-pillar because cars have gone through multiple hands during transportation, before the dealership picks it up from the truck. And down the road, you may see one or two very fine stone chips on the B-pillar for no reasons.
Avoid touching B-pillar panels and the stainless door trims on our IS are the ways to reduce marring.
FUZCO (03-10-17)
Anyone successfully hand polish them out without an orbital or DA?
Has anyone removed B pillars ?
Wondering if anyone has removed and replaced B pillars on any recent Lexus model? Mine were scratched in an accident and I would like to replace myself. Is this just taped on, or do they have clips (it appears the replacements don't come with clips so I am guessing that they do not use them anymore)? I'd appreciate any help. Thanks!
