Will a supra harness work?
Old 02-22-17, 08:57 PM
suprakidxx
suprakidxx's Avatar
Default Will a supra harness work?
I have a 5 speed 2jzge from out of a mk4, harness and ecu.
Along with pedals and drive shaft from another sc
I don't want my sc to be down long. Will the harness from the mk4 plug into the sc300?
1995 supra to my 1993 sc300 auto.
Old 02-23-17, 02:47 AM
gerrb
gerrb's Avatar
harness and driveshaft are not plug & play
Old 02-23-17, 06:08 AM
suprakidxx
suprakidxx's Avatar
whats different about the harness?
are the under the dash plugs at least the same?
Old 02-23-17, 06:23 AM
gerrb
gerrb's Avatar
that is the difference body plugs that are under the dash
Old 02-23-17, 06:44 AM
suprakidxx
suprakidxx's Avatar
there is a ton of info in your thread, my head is spinning trying to deciefer what is mk4 and sc3/sc4
https://www.clublexus.com/forums/bui...-toys-142.html
are the connectors phyically the same?
Just repin a wire on a few of them and use it?
Old 02-23-17, 08:21 AM
gerrb
gerrb's Avatar
This is the most updated non vvti 2jzgte wiring harness thread :
https://www.clublexus.com/forums/per...made-easy.html
Body Plug connectors between the SC and the MKIV are not the same . So it is not a matter of repinning . You would need the body plugs from the SC300 .
IneednSC
01-29-16 12:54 PM
xspsi6
18
11-09-12 06:52 PM
d1trainee
12
01-01-11 10:21 AM
Toshima
12-26-10 07:05 AM
Quick Reply: Will a supra harness work?
