2000 GS400 constant loud beep
Old 02-22-17, 03:27 PM
Kadrian21
Kadrian21's Avatar
Default 2000 GS400 constant loud beep
So here is the deal I have a 2000 gs400 and I lost all keys I just went to the dealer to get a new master key cut but not programmed I'm going to have a locksmith do it when I turn the car to the on position all I hear is a constant loud beep nonstop I didn't try to start it just turn on the electronics any idea what this is?
Old 02-22-17, 04:32 PM
burteboy
burteboy's Avatar
Default loud beep
Check the sun/moon roof is not closed properly.
Old 02-22-17, 11:25 PM
Kadrian21
Kadrian21's Avatar
I will double check but I believe I closed it could it be anything else?
Old 02-23-17, 12:45 AM
Kadrian21
Kadrian21's Avatar
The constant beeping noise did not stop the sun/moon roof is completely closed it appears to be coming from the dash on the drivers side and beeping doesn't stop
Old 02-23-17, 02:01 AM
Mr Jokster
Mr Jokster's Avatar
Sounds like the ABS. Pop the hood see if it's coming from the firewall where the computer is.
Old 02-23-17, 02:04 PM
Kadrian21
Kadrian21's Avatar
the car is reading p306 misfire on cylinder 6 I only hear the beep inside the car but close to the firewall on the driver side I can hear buzzing it buzzes and vibrates then stops the abs or fuel filter is vibrating can't tell which one
Old 02-23-17, 05:23 PM
Mr Jokster
Mr Jokster's Avatar
ok theres a code, lets start with that... Swap the coil on cylinder 6 with whichever, clear the code and see if the code follows where you swapped the coil. While you're in there, check the wires and the plug itself for damage.
I can think of why that would cause a buzzing/beep though.
Trvppizza
03-29-19 06:42 PM
GreddyEddy
Lexus Vehicles Classifieds
08-04-11 12:46 PM
02msmg3
06-16-11 01:55 PM
exe69
10-18-07 07:49 AM
brel523
07-24-06 10:52 AM
Quick Reply: 2000 GS400 constant loud beep
