tune up on a ls400 1997 first time need advice
Old 02-22-17, 02:05 PM
oldgregg
oldgregg's Avatar
Question tune up on a ls400 1997 first time need advice
About to replace the water pump timing belt ect on my 97 ls400. just wondering what everyone preferences are as far as company, ive seen dayco kits talked about alot. and ngk wires and plugs thats the plan right now but id love to hear what someone with more excperiance would suggest. and anyhing else i should do while im under the hood, currently at 208k miles. and 25k over the timing belt recommended replacement time
Old 02-22-17, 03:17 PM
Banshee365
Banshee365's Avatar
You need this kit: http://www.rockauto.com/en/partsearch/?partnum=TKT030 It contains components by the OE manufacturers for Toyota/Lexus. I wouldn't use anything else.
Follow my timing belt guide I created few months ago. It will match your car exactly. Post any questions you may have in that thread.
https://www.clublexus.com/forums/ls-...-belt-diy.html
Here is your wire set: http://www.rockauto.com/en/partsearch/?partnum=6718143
Here are your plugs: http://www.rockauto.com/en/partsearch/?partnum=PK20R11
The following 2 users liked this post by Banshee365:
RA40 (02-22-17), UNCNOR (02-23-17)
Old 02-23-17, 02:42 AM
Losiracer2
Losiracer2's Avatar
Make SURE you replace the Camshaft and Crankshaft seals. The whole reason for doing my Timing belt early was due to a blown and leaking crankshaft seal on mine, coating the entire Timing belt with oil.
Also, replace your coolant temperature sensor, as that can have a dramatic affect on fuel economy and driveability.
oldgregg (02-23-17)
Old 02-23-17, 10:22 AM
oldgregg
oldgregg's Avatar
got a recomendation for the sensor brand? rock auto has a alot of choices lol
Old 02-23-17, 10:55 AM
Banshee365
Banshee365's Avatar
You can get off RockAuto for the ECT sensor. I use RockAuto a lot, but not for that particular part. Hehe
I only go OEM on this part. If I needed to buy one today this is where I would get it: http://www.ebay.com/itm/GENUINE-TOYO...NYMgns&vxp=mtr
oldgregg (02-23-17)
Old 02-23-17, 10:58 AM
oldgregg
oldgregg's Avatar
thank you my man, ive got a pro mechanic helping me do this tune up and your great advice i dont know what id do without the help!!
Old 02-23-17, 03:46 PM
oldgregg
oldgregg's Avatar
another question i need the dstb cap and such and recomendations?
Old 02-23-17, 07:02 PM
Banshee365
Banshee365's Avatar
RockAuto doesn't carry Denso caps and rotors but I'm pretty sure Denso is the OE for Toyota/Lexus. I would typically buy the OEM caps and rotors as the price isn't insane. My parts source has the caps for around $20 each and the rotors for $11 each. I would be comfortable using the Bosch parts on RockAuto if you want to keep it in the same order as the parts I linked to there for you like the timing belt kit and such.
The OE part numbers are:
Rotor: 19102-50020
Cap: 19101-50020
I use Lexus of Pembroke Pines Parts A LOT, have for years and years. They are in South FL. Their website is LPPParts.com. I use LexusSouthAtlantaParts.com for the dealer level parts diagrams to get the numbers and punch them into LPPParts.com I've ordered from Lexus of South Atlanta Parts as well and they are super nice to deal with.
Old 02-24-17, 03:40 AM
Losiracer2
Losiracer2's Avatar
I just bought an Import Direct part from Oriellys. It has a lifetime warranty, so if it'll ever break I'll take it back and exchange. I went there mainly for convenience. If you order at a dealer, they'll most likely have to ship it in from somewhere, leaving you SOL if you have to work the next day and it's your only means of transportation. There are plenty of Oriellys nearby, so I always have multiple options to go to. I think I paid 17 bucks for it.
vindell
03-23-13 12:42 AM
qewani1
09-07-11 05:16 AM
DK Audio
07-29-10 02:40 AM
esc88LS400
03-18-10 08:35 PM
Banshee365
Maintenance
11-28-06 09:46 AM
Quick Reply: tune up on a ls400 1997 first time need advice
