Moonroof gets stuck
Old 02-16-17, 06:05 AM
leg3ndary
leg3ndary's Avatar
Default Moonroof gets stuck
What's up folks, so my moonroof gets stuck on hot days and if sitting out in the sun (75+). I click the button and I can hear the latch engaging, but the moon roof does not slide at all. I live in Houston so heat is inevitable. I wanted to see if anyone else is having the same issue.
Old 02-16-17, 08:17 AM
phins2rt
phins2rt's Avatar
What year? Do you need to clean the tracks or lube the seals? Does it operate normally when it is cooler (<75 degrees)? Or it doesn't operate at any temperature?
Old 02-16-17, 12:53 PM
kamskeez
kamskeez's Avatar
I haven't heard of this issue. Very strange though. Are you covered under warranty still?
Old 02-18-17, 07:54 AM
leg3ndary
leg3ndary's Avatar
It's a 2014, it only happens when its 70-75+ and has been sitting out in the sun. When it's a cool day and not in the sun, it works great,.
Old 03-24-17, 11:08 AM
leg3ndary
leg3ndary's Avatar
Ok, update on this nagging issue. My moon roof no longer opens automatically and now it's making some weird noises. I've got a serious problem. Anyone have any recommendations or thoughts?
Old 03-24-17, 11:10 AM
bclexus
bclexus's Avatar
Received 1,996 Likes on 1,418 Posts
It sounds like it is something you probably cannot fix. Why not make an appointment and take it to your Lexus dealer?
LatinLS430 (03-24-17)
Old 03-24-17, 11:33 AM
leg3ndary
leg3ndary's Avatar
It seems that way for me too, real big bummer. It's a $2,000 to replace the whole unit. I can't justify that..
Old 03-24-17, 11:55 AM
bclexus
bclexus's Avatar
Since it is a 'body part' (in lieu of drivetrain) you may want to speak with a body shop about it...
Old 03-28-17, 08:23 PM
Ehsun
Ehsun's Avatar
I haven't seen this before. Maybe contact a delar and see what's up
Old 03-28-17, 09:39 PM
SunnySoCal
SunnySoCal's Avatar
Happened to me also that roof would get stuck occationally until it died last month. Dealer install new moon roof motor
krawfo
05-10-19 01:45 PM
S54toIS350
03-19-15 11:21 PM
fxiong1
02-07-11 06:53 PM
itsZep
GX - 1st Gen (2004-2009)
12-03-07 06:17 AM
t0e
12-28-06 11:42 AM
Quick Reply: Moonroof gets stuck
