2010 LS 460 foglights
Old 02-08-17, 05:42 PM
JH48
JH48's Avatar
Exclamation 2010 LS 460 foglights
both side of my foglights wont light up.
I looks at the fuse it blows, but then i changed it and it still wont light up..
Does anyone know what is going on?
Old 02-08-17, 07:44 PM
roadfrog
roadfrog's Avatar
Depends. Did the replacement fuse blow as well? A fuse usually blows for a reason....short, etc. Look at the fuse again, if its blown, you have a problem. If it's still good, you need to check your relays.
Old 02-08-17, 10:17 PM
JH48
JH48's Avatar
Yes it blown 3 times. Should i just replace the whole HID kit?
Old 02-08-17, 10:25 PM
dlbuckls10
dlbuckls10's Avatar
Probably safer to have the problem checked out by a tech than to replace the whole kit and you could still have a problem.
Old 02-09-17, 08:14 AM
roadfrog
roadfrog's Avatar
Exactly. You have a short somewhere.
Old 02-09-17, 12:15 PM
Oliver Enterprises
Former Sponsor
Oliver Enterprises's Avatar
Is it an HID kit you have installed? Meaning, not the OEM fog lights?
Old 02-09-17, 12:27 PM
JH48
JH48's Avatar
Cool
yes hid kits. Should i try with regular bulb first?
Old 02-09-17, 12:30 PM
CRowe14
CRowe14's Avatar
I personally would try the OEM bulbs first.
Old 02-25-17, 12:28 PM
JH48
JH48's Avatar
Replaced my 6000k garax to morimoto 5500k. Low beam. Please give some feedback on which output light better
Left is garax 6000k and right is 5500k moritomo
Left 5500k morimoto vs 2013 gs350 stock low beam
Old 02-25-17, 07:46 PM
comotiger
comotiger's Avatar
The Morimotos provide better output in both pics.
Old 02-25-17, 08:18 PM
CRowe14
CRowe14's Avatar
I agree with comotiger.
It appears the light dispersion cast a wider beam of usable light. Really bright, white light.
pewterss
02-04-18 03:03 PM
nammer
RX - 3rd Gen (2010-2015)
04-16-15 07:09 PM
KI_GSE21
05-05-10 09:18 PM
kevintq
01-24-10 06:17 PM
Quick Reply: 2010 LS 460 foglights
