Number 1 cylinder dead when warm at idle
Old 01-23-17, 07:09 PM
Scoozy009
Scoozy009's Avatar
Default Number 1 cylinder dead when warm at idle
I've searched here, Facebook, Google, YouTube, and other forums and nothing
I have a 93 ls and when it's warm at idle number 1cylinder quits, every ignition component is new and works
All cylinders spark like they should, has good compression, and fuel to all cylinders, I've grounded out the #1 injector while plugged in and running and the car stumbled I don't know what else could cause this to happen
It couldn't be the ecu by theory because number 1 and 7 are controlled by the same driver in the ecu
Old 01-24-17, 04:36 AM
deanshark
deanshark's Avatar
Might be more ideas but my only thought would be to change the #1 plug wire with a known good old wire to see if it still happens. Might be bad insulation on that wire or it could have been pinched when you put everything back together.
Old 01-24-17, 05:01 AM
fixmiester
fixmiester's Avatar
Default Good troubleshooting so far
Your approach is solid. Might be a partially clogged #1 injector, but hard to say without visually testing. If you have a scope, you can compare the injector pulse signal with the others, which may reveal an ECU issue, or bad connection. Could also shoot some injector cleaner right into the injector at the fuel rail, and let it work for an hour before starting it up. Good luck.
Old 01-24-17, 08:57 AM
Scoozy009
Scoozy009's Avatar
I've used an led test light pulse looks (by eye) exactly like 2 & 3 easy injectors to get to flashes just the same as 1 does
Old 01-24-17, 04:13 PM
Scoozy009
Scoozy009's Avatar
Default New test just now
Swapped number 1 & 2 spark plug wire and no change
Pulled the injector and pulse cleaned it with brake cleaner, spray pattern looked great (wide angle, thin and long stream) could it be a battery issue?
Old 01-25-17, 01:37 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
swap the ECU. Have you properly tested your ECU?
If you're 100% confident in ignition and fuel, the ECU isn't a bad place to pay attention to. There's no systemic issue (ie- battery) that would only adversely affect 1 cylinder if the other systems are running properly.
Old 05-29-17, 07:51 PM
shamanic
shamanic's Avatar
Did you ever figure this out? I'm having same problem.
Old 05-30-17, 09:07 AM
djamps
djamps's Avatar
Check the suspect injector's ohms reading compared to others when it's working vs not working.
scmaluco
Performance & Maintenance
12-14-15 07:15 AM
p00rbob
03-03-13 12:55 AM
williamb82
09-11-12 03:41 PM
grindin8o8
15
05-05-11 01:23 PM
Bean
04-23-02 07:31 AM
Quick Reply: Number 1 cylinder dead when warm at idle
