Reversed polarization of jumper cables
Old 01-20-17, 02:00 PM
jon2ly
jon2ly's Avatar
Question Reversed polarization of jumper cables
Well let me start by saying what I did was completely stupid. I jumped started our is350 from a gmc sierra to a completely dead battery in the is350. I unintentionally revetsed the cable polarization. I tried to start the Lexus, but got no response. Then I smelled the battery cable plastic coverings melting. I yanked them off before a fire started, let them cool and corrected the cables. The Lexus started, but the radio did not work, the check engine light came on, the "check vsc" appeared and the engine shut down and wouldn't accelerate past idle. I checked the fuses, at least the common ones and did not see any were blown. I have no close Lexus dealer, but had the car towed to Toyota of San Luis Obispo for service. I have not yet been advised of the diagnosis but am concerned that I may have fried the computer, meaning many $$$. Has anyone had a similar experience and found they had to replace the computer? Thank you for any advice, besides "check the cables next time Ding Dong".
Old 01-20-17, 02:15 PM
getafewliv
getafewliv's Avatar
Don't quote me on this, but I am pretty sure I have read in the past about this happening and there's a special main fuse that blows. I would google it for you, and could probably find the answer, but since I didn't screw up jump starting a car, I will leave it up to you.
Old 01-20-17, 03:20 PM
jon2ly
jon2ly's Avatar
Default Thank you getafewliv
Yes, I will followup on the main fuse aspect and hopefully that will be the diagnosis. It's a lot cheaper than a new computer. By the way, learned a great lesson. Toss the cables and use a charging pack.
Old 01-20-17, 05:06 PM
getafewliv
getafewliv's Avatar
I keep one of these in the car:
https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1
This way I can always jump start my own vehicle if necessary, and I have an emergency USB battery backup.
Old 01-20-17, 07:07 PM
srt1
srt1's Avatar
Its a fusible link or main fuse under the hood. I'd check all of them just to be safe. It's a pain to replace the fusible link but you can still do it yourself. My link blows out at the battery cause I have an anl fuse which is easy to replace which blows out first.
Old 01-23-17, 05:49 PM
jon2ly
jon2ly's Avatar
Well the Toyota Service Mgr thinks it needs a new throttle body and the part only is $1500-2,000.
I ask them to confirm their diagnosis with Lexis. Final diagnosis showed a blown ecu fuse. Final cost: $62.50. Thank you Lexus for that fuse protection.
Old 01-24-17, 07:51 PM
nosurprise
nosurprise's Avatar
wouldn't the lesson be don't reverse the cables? :p
Old 01-24-17, 08:17 PM
jon2ly
jon2ly's Avatar
Well, yes. Not like it was intentional; driving rain, darkness and dirty terminals, but thank you for your remark. Not!
Z28302 (04-28-19)
Old 01-24-17, 08:23 PM
Kmasyl
Kmasyl's Avatar
Double check every fuse in the fuse box. I had accidentally installed a battery backwards and it took out the fuse link (not your issue), and a handful of small fuses. One of the smaller fuses being blown caused the same issue you are experiencing. It would just idle and not accelerate. I don't recall the exact fuse it was, but I can say my symptom was the same as yours.
jon2ly (01-24-17)
Old 01-25-17, 06:53 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Funny, I did the same thing, but it just induced a ginormous spark fest, and was done. Everything worked fine. You're not alone...haha
Old 01-28-17, 02:38 PM
jon2ly
jon2ly's Avatar
Default Reversed polarization of jumper cables
Two other things happened; radio went dead and the passenger windows would not roll up or down from the driver master control. Both were easily fixed. A 10 amp fuse on the passenger side fuse box fixed the radio and by going to each door window switch, I rolled each window up and then down holding the switch on in both positions for three seconds. After doing that, the master switch worked fine. The IS is back to the fine machine it is.
Parsa
03-03-16 04:09 PM
Thasis
06-07-13 06:08 PM
cherishzm
05-31-13 12:02 PM
carmelite
08-15-11 01:36 PM
black_LS
03-03-08 05:20 AM
Quick Reply: Reversed polarization of jumper cables
