Custom settings
Old 01-19-17, 07:45 AM
RiverBend
RiverBend's Avatar
Default Custom settings
I can see some custom settings like (door locks, lights, etc) but I can't highlight them to change them. Are all these type settings dealer only or should I be able to change some of this myself?
RiverBend
Old 01-19-17, 08:04 AM
RCMike
RCMike's Avatar
My Lexus dealer sent me the attached file so I can fill it out and bring it with me when it's time for my 6 month service. At that time, they will perform a one time customization without cost. It also details what can be changed by the user and the dealer.
Old 01-19-17, 09:37 AM
RiverBend
RiverBend's Avatar
Well I didn't get mine from a lexus dealer so I guess they won't be doing that for me unless I pay them. From the PDF it looks like I should be able to change some things like door locks, etc. Maybe I am doing something wrong. Just trying to get some feedback from someone who has changed these settings on the RC350 Fsport.
Thanks,
Riverbend
Old 01-19-17, 11:10 AM
RCMike
RCMike's Avatar
You should be able to customize the first 15 settings on the list with the instructions on page 1. The rest you will need to go to the dealer or get something like Carista. What exactly are you trying to customize?
Old 01-19-17, 11:12 AM
RCMike
RCMike's Avatar
One more thing, make sure your car is in park when you're doing this. When the car is moving, I believe you cannot change them.
Old 01-20-17, 01:17 AM
Carista
Former Sponsor
Carista's Avatar
Just for your reference, you can change the "dealer-only" settings, plus some more, with the Carista app and adapter. Below is a sample list for what's changeable via Carista on a customer's 2015 RC-F. The price is $39.99 for the adapter (which gets you a 1-month free trial of the app), and then $39.99/year for the Pro features in the app (or alternatively, get a 1-week pass at $9.99 whenever you need it, without a subscription). In my opinion, much more convenient and cheaper than going to the dealer.
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
YES / NO
Beep when locking/unlocking with remote
YES / NO
Volume of beep when locking/unlocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / MAX
Beep when opening/closing windows with remote
YES / NO
Warn (beep) when door can't be locked because it's still open
YES / NO
Warn (beep) when a window is still open when locking doors
YES / NO
Warn (beep) when sunroof is still open when locking doors
YES / NO
Panic function on remote
ENABLED / DISABLED
Open trunk lid with remote
SINGLE CLICK / DOUBLE CLICK / LONG PRESS / VERY LONG PRESS / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
YES / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Auto-lock all doors
DISABLED / WHEN SHIFTING INTO GEAR / WHEN VEHICLE STARTS MOVING
Auto-unlock all doors
DISABLED / WHEN SHIFTING INTO PARK (P) / WHEN DRIVER'S DOOR IS OPENED
Unlock trunk when doors are unlocked
ON / OFF
After locking with smart key, don't allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT SEATS / ANYWHERE IN VEHICLE
Unlock trunk when smart key in range
YES / NO
Open windows and sunroof by holding key in door lock
ON / OFF
Close windows and sunroof by holding key in door lock
ON / OFF
Open windows and sunroof via long-press on remote
ON / OFF
Lower passenger-side mirror when in reverse gear
DEFAULT / USER-SPECIFIED
Instruments / Display / Dings:
Engine start indicator
ON / OFF
Display odometer after ignition is turned off for…
30 SECONDS / 1 MINUTE / 10 MINUTES / OFF
Ding when headlights are left on
YES / NO
Seat belt warning ding (driver)
ENABLED / DISABLED
Seat belt warning ding (front passenger)
ENABLED / DISABLED
Turn signal click volume
LOW / MEDIUM / HIGH
Remote low battery warning
ON / OFF
Rear parking sensor range
NARROW / WIDE
Mute parking sensor when stationary for more than 3 sec.
YES / NO
Activate parking sensors in neutral (N)
YES / NO
Enable front parking sensors when in reverse (R)
FRONT / OFF
Enable rear parking sensors when in neutral or forward gear
REAR / REAR CORNER / OFF
Dash display mode
ALL / UNDISP
ECO Drive indicator zone
ON / OFF
Lights:
Daytime running lights
ON / OFF
Coming-home lights duration
OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
Turn on marker lights when vehicle is unlocked via remote
ON / OFF
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / 15 SECONDS / 30 SECONDS
Turn on interior lights when you shut off engine
YES / NO
Turn on interior lights when you unlock doors
YES / NO
Turn on interior lights when smart key in range
YES / NO
Turn on exterior footlight (on side mirror) when smart key in range
YES / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
YES / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
YES / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / 15 SECONDS / 30 SECONDS
Interior lights linked to footlight
YES / NO
Interior light control
ENABLED / DISABLED
Exterior light control
ENABLED / DISABLED
Heater & A/C:
A/C power
AUTOMATIC / FULL POWER
A/C ECO mode
ENABLED / DISABLED
Auto-increase blower speed when front defroster is on
YES / NO
Auto-turn on A/C when AUTO button pressed (if needed)
YES / NO
Deactivate front defroster when AUTO button pressed
YES / NO
Also blow to feet in "face" mode
YES / NO
Seat heater mode
AUTOMATIC / MANUAL
Fan speed reaches its target…
SLOWLY / NORMALLY / FAST
Old 01-20-17, 07:19 AM
RiverBend
RiverBend's Avatar
Found my RC has to be started before I could get to those menus. I was able to get into and play with all the settings accept the dealer only ones. Still exploring my RC as I bought it used and I new more about the car than the salesman. All info and tips are welcomed.
Riverbend
Old 01-21-17, 11:09 AM
ba2sy
ba2sy's Avatar
Carista, do you think you can add the Remote Start feature options like Keep Engine Running after opening doors when key is in range? I like this feature on Viper Smart Start on my non-lexus car. The car will only shut down if after 10mins key is not inserted or key not found while pressing the brake pedal to change Parking Gear to Drive Gear, etc. I want to start the car in advance to warm up the engine, cool down or warm up the interior then, unlock doors, enter the vehicle within 10mins and drive if key is detected within range of 3-5 ft.
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
ENABLED / DISABLED
YES / NO
Auto-lock all doors
ON / OFF
YES / NO
ON / OFF
ON / OFF
ON / OFF
ON / OFF
YES / NO
ENABLED / DISABLED
ENABLED / DISABLED
LOW / MEDIUM / HIGH
ON / OFF
NARROW / WIDE
YES / NO
YES / NO
FRONT / OFF
Dash display mode
ALL / UNDISP
ON / OFF
Lights:
ON / OFF
ON / OFF
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
ENABLED / DISABLED
ENABLED / DISABLED
Heater & A/C:
A/C power
A/C ECO mode
ENABLED / DISABLED
YES / NO
YES / NO
YES / NO
YES / NO
Seat heater mode
AUTOMATIC / MANUAL
Old 01-23-17, 09:15 AM
Carista
Former Sponsor
Carista's Avatar
I haven't experimented with this myself, but as far as I know, the engine keeps running even if the key is not within range. It's just that it can't be started that way. Or am I mistaken?
Old 01-23-17, 10:59 AM
ba2sy
ba2sy's Avatar
The engine keeps running even when the key is in range. But the problem is that the engine shuts down when you open the door. On my Viper Smart Start, remote start the car, you unlock/disarm the alarm, open the door, put in the key, turn ignition to on position, press brake pedal, change Park gear to Drive gear and you're good.
Old 01-23-17, 07:54 PM
Landonre
Landonre's Avatar
Does anyone know what the following setting (from the list of settings specified above) is?
Dash display mode
ALL / UNDISP
I have Carista, but cannot find anything that indicates what this setting actually does.
Also I would appreciate if anyone could chime in if they know of the setting(s) to change the following:
1. Default the speed/info display to be moved over to the right without having to press the button every time you start the car? It currently defaults to the center and I prefer the other display
2. Default the main display to the home screen. I don't use my built in GPS because Waze on my phone is better (extremely accurate with maps, traffic, police, accidents etc.) and because Waze frequently updates the maps at no charge. The main display "likes" to default to the GPS or radio settings, but I really don't need either and would rather have the home screen with my customized displays without having to press the home button every time I start the car.
Any help would be appreciated!
Old 01-24-17, 12:03 PM
lexual_rc
lexual_rc's Avatar
This was very useful...didn't even know it was possible to control windows/sunroof with the remote. Is there any option for the auto start to not shut off when you unlock or open any doors to the car once started?
Old 01-24-17, 12:07 PM
mjeds
mjeds's Avatar
I will second CARISTA. I bought it and customized the settings on my RCF and my wife's Camry.
Old 01-25-17, 12:30 PM
GearHead69
GearHead69's Avatar
I've had the CARISTA app for a little over 2 years now and love it. The remote start will only work if you have a paid subscription to Lexus Enform Safety & Connect.
Old 01-26-17, 09:25 PM
Megafast13
Megafast13's Avatar
I'll buy if I can make it so the engine doesn't shut off when I open the door when I start it from afar. Makes no sense.
Quick Reply: Custom settings
