Thermostat Housing Bolt Torque
I am replacing the thermostat (car is slow to warm-up and running a little cooler than normal) on my 2004 RX330.
My Haynes manual says 8 NM / 71 in-lbs for the torque on the thermostat housing bolts, can anyone confirm these values with a factory shop manual?
Thanks, Joe
Thanks, Joe
Your specs are fine, try not to overthink the torque, though it be important. 71 inch pounds or around 6 ft lbs of torque is good. I have replaced that exact housing and had no issues.
Thanks. I torqued it to the value in the Haynes manual and it felt right. No leaks on start-up.
After I was done I was able to confirm that is the correct value.
Aloha, Joe
Aloha, Joe
7MDriver
Performance & Maintenance
10-14-08 09:03 AM
