Adding subwoofer to Mark Levinson sound system
Old 01-16-17, 10:16 PM
yambs
yambs's Avatar
Default Adding subwoofer to Mark Levinson sound system
I want to add a subwoofer in the trunk of my 07 GS 350. Will I be able to straight up plug and play to the existing ML amp? If not, how painful will it be to make this possible?
Old 01-17-17, 11:07 AM
XxGoKoUxX
XxGoKoUxX's Avatar
If you match the ohm load of the OEM subwoofer, then yes its possible. It's not worth it though...
If you don't match the ohm load (say put a 4 ohm load on a 8 ohm amp) you'll either put the amp into protection mode or you'll burn the amp out (these ML amps aren't cheap).
yambs (01-17-17)
aWorkOfArt
RC F (2015-present)
17
09-22-22 06:05 AM
Mrhaggiz
07-01-19 11:09 AM
Robles84
05-24-18 06:23 PM
Mhobizal
ES - 6th Gen (2013-2018)
03-09-15 06:41 PM
IS Pilot
09-29-04 09:10 PM
Quick Reply: Adding subwoofer to Mark Levinson sound system
