4th gen es300 factory hids to aftermarket hids
Old 01-16-17, 08:48 PM
Shawnito
Shawnito's Avatar
Wink 4th gen es300 factory hids to aftermarket hids
Sorry i need help! i have the d2r factory light bulbs. i bought a aftermarket kit aftermarket kit
everything hooks up but this part
what am i doing wrong? do i even need that plug in? cause there is no where to plug it in coming from my car...
Old 01-16-17, 09:32 PM
Received 2,707 Likes on 2,292 Posts
That kit is for upgrading a non HID system the connector you are asking about would go to the conventional headlight connector.
Old 01-17-17, 12:19 AM
Shawnito
Shawnito's Avatar
should i return/sale this kit and buy another kit? or is their a way to make this kit work??
Old 01-17-17, 09:45 AM
You should return the kit or sell it off your car already had HID lamps an aftermarket kit won't improve your lighting much if at all. If you want a different colour and/or somewhat brighter bulbs then you can get replacements. To get a more modern look and better light you'll need to retrofit projectors into your housings.
Old 01-17-17, 12:10 PM
Shawnito
Shawnito's Avatar
im looking for that deep blue 10000k look and the stock halogen lights arnt't doing it for me....
Old 01-17-17, 12:32 PM
WILLYumD
WILLYumD's Avatar
The higher temperature you go, the less usable light there will be. Yes, aesthetics are cool, but don't forget your headlights are a safety mechanism. 4500k is an OEM color, 5500k is a more natural white, and 6500k you'll be getting a blue tinge, 8000k and it'll be blue (and significantly less light output).
For your own safety, I strongly recommend not going above 6500k. There's a reason why reputable HID sellers don't really sell bulbs hotter than 6500k.
Old 01-17-17, 01:20 PM
There are a zillion D2R xenon bulbs on Ebay in just about any colour you want. But don't be "that guy" and go with a 10k lamp you won't be able to see properly and you'll annoy other drivers.
Old 01-17-17, 01:22 PM
RXGS
RXGS's Avatar
10k is pretty dumb. 6500 is the most you should go to get a bluer look while still having usable light and to do that all you need to do is buy the correct bulb that fits your HID just at the desired temp. I must be in the minority that thinks blue headlights look cheap.
Old 01-18-17, 03:40 PM
speedkar9
speedkar9's Avatar
So does your car have stock halogens or HID's as per the title of this thread?
If you have an 05-06 with projector halogen lights, an HID kit won't work well in there, because the cut-off shield will block a lot of light, I've tried it myself.
If you have factory HID's in 02-04 ES300 housings then all you need is replacement D2R bulbs with a different color.
Old 01-18-17, 03:44 PM
Profile says his car is a 2003.
MI350_55
Lighting
01-07-09 11:00 PM
w0by
Lighting
03-04-07 07:36 PM
nkt001
Lighting
01-08-06 09:13 PM
kgh31386
Lighting
01-04-06 05:48 PM
Fusion400
GX - 1st Gen (2004-2009)
02-19-04 08:57 PM
Quick Reply: 4th gen es300 factory hids to aftermarket hids
