2008 Rx 350 Water Pump/A/C Compressor
Old 01-16-17, 09:09 AM
rsteve12
rsteve12's Avatar
Default 2008 Rx 350 Water Pump/A/C Compressor
Hello Everyone and Happy New Year,
The water pump on my 2008 RX 350 with 157,000 miles failed and caused the belt to come off and I lost all or most of the coolant. Luckily I was only two miles from home. I ordered a new AISIN water pump and it is supposed to be here Wednesday. I read some good threads on here and I've decided to replace it myself. I just have one question:
Should I replace anything other than the water pump and gaskets while I'm in there - idlers or tensioners, timing chain?
Thanks Very Much,
Russell
Old 01-16-17, 12:35 PM
Lexuswiz
Lexuswiz's Avatar
You can always change them if you want preventative maintenance but ever since Toyota switched to chain, most parts such as the idlers and tensioners are replaced on a need bases unlike timing belt engines where everything is on an interval. But I'd consider the thermostat and gasket since you're in the area (use OEM parts only).
Personally, you'll never need to touch the chain itself if your engine is in good shape. My buddy is pushing 354K on his '09 Camry which is timing chain and hasn't replaced a part involving the chain timing.
Old 01-16-17, 04:05 PM
toyoman29
toyoman29's Avatar
I would also replace thermostat, belt and new radiator cap, I would also use OEM parts and the pink Toyota coolant. The AISN water pump is OEM and should work great, I usually get those too.
Old 01-22-17, 11:35 PM
rsteve12
rsteve12's Avatar
Default Now No Heat
Thanks for the replies, fellas.
I finally got the water pump installed. Quite possibly the most difficult repair I have ever undertaken - a real PITA.
I did not open the drain plugs on the radiator and drain it since most of the coolant leaked out when the pump failed. When I finished the install, I added about 1.5 gallons of coolant with the engine running and the a/c set to max high, but the air never got warm. According to my OBDII reading, the water temp reached 185F and still no heat. Any Ideas?
Old 01-23-17, 07:14 AM
Lexuswiz
Lexuswiz's Avatar
Just to be clear, did you set it to max heat or a/c? If you did set it to max heat and your post was a typo, could be 2 things: 1. low coolant/still air or 2. thermostat stuck or slow to engage.
Old 01-23-17, 07:50 AM
rsteve12
rsteve12's Avatar
Thanks. I set the a/c to max high temp. I'm gonna run for awhile with the cap off.
Old 01-23-17, 07:58 AM
Lexuswiz
Lexuswiz's Avatar
Also jack up the front of the car if you can so the cap is the highest point of the cooling system.
Old 01-23-17, 11:12 AM
rsteve12
rsteve12's Avatar
Seems to be heating, now. I drove around town and then added more coolant and got more air out.
Thanks for all your help.
Old 01-27-17, 04:44 PM
snydertalo
snydertalo's Avatar
If you haven't installed it already, would you be willing to take a few pics of the install. And maybe note any point which you got really frustrated and then how you solved the issue? These are two things I am looking at installing to prevent issues like these.
RX4UNME
RX - 3rd Gen (2010-2015)
10-31-18 01:02 PM
GSRockstar
09-26-18 01:13 PM
GibbsLexus
08-09-17 07:18 AM
Harvey99
05-30-15 08:04 AM
mian
Hybrid Technology
02-11-14 05:03 PM
Quick Reply: 2008 Rx 350 Water Pump/A/C Compressor
