Best Intake pipe for the RCF ?
Hello guys ,
I'm looking to get best ,reliable and most power gaining intake pipe in the market for the RCF if you guys can help me out of which to buy .
Thanks ,
Omar
Thanks ,
Omar
Just pick which one you like the best. Like ^^he said....its a pipe, reliability is not in the equation.....and changing it alone adds no performance value. Its more or less an aesthetic change to suit your mood. I would go with a pipe that does not provide heat-soak, ie silicon or carbon fiber. Now some kits come with a filter too like Apexi, and you may see some marginal gains due to a better breathing filter, again, not very much....
I went with the Most Expensive one (Lems) but then again I was going Mostly on Looks (to me this one is the Best Looking one on the Blue Mica cars) but you can get them A LOT Cheaper & they ALL pretty much DO NOT ADD any Extra HP or Torque! You're NOT going to Notice any Extra seat of the pants feel.
no going to get much in the way of gains.. mostly just increased noise, and decreased mpg.
I had a custom one made, actually lost power on the dyno.
AEM/K&N used my car for their digital wire frame and design for their intake, the K&N is a smooth pipe and filter, AEM will be releasing a full CAI system within a few months.. Hopefully they will have a little better luck with power gains..
but without any available tuning for the RCF, eventually the computer will compensate for the added air flow and you'll be back to stock numbers, or lower (as I saw with the custom one).
doesn't really matter which brand you use, any intake will not add any power to the car, only looks, sound, and as I said reduced MPG (mostly because the increased sound results in a heavier right foot).
HPS is one of the most popular ones we sell. Bolts right in with no power loss
__________________
Email:sales@jmautoracing.com
AIM: jmautoracing@gmail.com
www.jmautosports.com
1-855-998-8726
1-855-998-8726
I don't think the stock one is restrictive at all compared to aftermarket ones. But if I were to get one, it would be the HPS silicone one or Apexi I think makes one too. I just don't like adding two more clamps in the equation like the metal ones that use couplers on each end. For now though, I'm keeping the stock one.
Drop in a K&N filter and call it a day, unless you're after a cosmetic change. Nothing I've seen have shown any worthwhile gains over the stock setup. If you want to move more air, open up the restricted exhaust.
Clamps/Couplers on the OUTSIDE of the tube has NUTHIN' to do with the Air-Flow on the INSIDE! & YEAH I think RIBBED vs SMOOTH definitely makes a Difference, IF NOT why does EVERYBODY do it in EVERY car? ALL of my Viper Buddies do it, ALL of my Porsche buddies do it, ALL of my H2 buddies do it, ALL of my BMW buddies do it, DO I need to go on? But, it's Not going to gain you an Extra 20hp & torque!
Also, someone already mentioned, although I haven't verified, the stock one ISN'T ribbed on the inside.
