PICS: HID Headlight Restore Before/After
Old 01-15-17, 08:50 AM
SenecaRex
SenecaRex's Avatar
Thumbs up PICS: HID Headlight Restore Before/After
I've had these headlights sitting in my garage for over a year, so I finally found some time to clean them up and put them on the car.
As you can see on the left, they were heavily oxidized and just a general eye sore. After about an hour or so of elbow grease, it now looks close to new, but more importantly it's regained it's use as a functional HID headlamp with proper light disbursement.
For anyone still on the fence, definitely take the time to restore your headlights.
Update 1/20/16 – Installed on the car:
firelizard (01-15-17)
Old 01-15-17, 12:35 PM
dreamcar88
dreamcar88's Avatar
Did u use clear?
Old 01-15-17, 12:38 PM
SenecaRex
SenecaRex's Avatar
Originally Posted by dreamcar88
Did u use clear?
Yes, UV resistant clear coat was used.
Old 01-15-17, 01:07 PM
SpectraBlu
SpectraBlu's Avatar
Looks good, nice job
Old 01-15-17, 05:42 PM
nelson09
nelson09's Avatar
Nice work, took an easy 10 years off the car for sure!
Old 01-15-17, 06:24 PM
ThomasGS4
ThomasGS4's Avatar
Very nice. It makes me wonder why others don't take 10-15 minutes to do the same...a lot safer and more visually appealing.
Old 01-16-17, 04:19 PM
SenecaRex
SenecaRex's Avatar
Thanks, all. Just swapped the headlights out. Will post sample pic soon.
Old 01-20-17, 07:46 AM
SenecaRex
SenecaRex's Avatar
Update: posted pics of it on the car
Old 01-20-17, 08:40 AM
LexusK
LexusK's Avatar
Looks super blotchy..? Runny..? Orange peel-y...? Lol not sure what the word for it is. Can that be cleared up?
Old 01-20-17, 08:44 AM
SenecaRex
SenecaRex's Avatar
It's orange peel.
It's very noticeable up close. A foot or more away and you cant see it, nor does it really affect the lighting, thankfully.
I'll probably wetsand it down eventually. But since it's not functionally impaired, and only visible when closely inspecting, the wetsanding detail just isn't a priority.
Old 01-23-17, 05:56 AM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
They should've been glass from factory, then this would've never been an issue. If Lexus didn't go cheap with plastics, their buyers would never have to do that. My 01 GS has plastic headlamps, my roommates 00' Impreza RS has glass ones.....makes 0 sense.
Rant aside, they came out great. The biggest point people seem to forget to do is applying that clearcoat. You can polish the crap out of them, and they'll look brand new, but don't clear em, and within a month they'll be yellow again.
Old 01-24-17, 06:21 AM
ericherm1
ericherm1's Avatar
Exclamation
I don't want to rain on anyone's parade here but this comment is absolutely false. If the job was done right there is no need to apply any clear coat. The only purpose for anyone to clear coat a head light is because they do not intend on doing any continued maintenance. The original intent was based on temporally solving an issue without replacing expensive light assemblies typically incurred in used car dealerships.
I've been in the body and paint business for going on 25 years and every job I've done with regular upkeep has lasted the time I've owned them and longer. The key is doing the job right the first time. Cutting the plastic with a good 800 grit wet and getting rid of all the haze the first go around before you move on the the 1200 grit. Finishing off with 2000 and and a decent compound is vital for the last sealing polish. Regular upkeep includes waxing and polishing your head and tails when you wax and polish your paint. This is where most people who undertake this fix forget to include.
Example, I did this to my headlights back in December 2015 and have yet see any change in clarity.
You don't need clear to maintain a nice finish, in fact in MY opinion clear coating headlights is cheap and the fast way around what should be a time taken professional end result.
Old 01-24-17, 10:32 AM
Jewcano
Jewcano's Avatar
^And I've done multi stage sanding before as well, and polished, HOWEVER after a month or so, it would yellow again if left to the elements. Not everyone is religious with their upkeep and I'd consider yourself the minority in regards to that. So for most people, once you sand the headlight, removing what little UV coating remains, exposing the plastic to the suns UV rays leading to the plastic oxidizing, it just makes more sense to have the headlight coated with a fresh UV clearcoat to protect it and not have to worry about polishing it every so often to maintain that new look.
Old 01-24-17, 11:48 AM
ericherm1
ericherm1's Avatar
Actually I only wax them every 5-6 months when I wax the car..... nothing much more than that. So since I did them they've only been waxed maybe 2x. A good polish will provide the same level of UV protectant without drying out like shaker can clear often does over time. Just my experience and opinion. I respect yours as well.
Old 01-24-17, 12:16 PM
ThomasGS4
ThomasGS4's Avatar
A lot of variables here such as location/weather conditions, whether the car is garaged at night, parking garage during the day etc.
Quick Reply: PICS: HID Headlight Restore Before/After
