Recommendation on CV Shaft?
Old 01-11-17, 09:39 AM
jaredmac11
jaredmac11's Avatar
Default Recommendation on CV Shaft?
1997 ES300
I had plans to update my entire suspension but money is a bit tight... that being said I absolutely need to do the CV shafts on my car. I hear a popping noise when I turn at low speeds (in car garages for instance) so I feel like they are on their way out.
Besides OEM, what would be a good manufacturer to get CV shafts for both sides? Anything else I absolutely should do while Im under there?
I was hoping I could do a full refresh of everything at once but I just dont have the money.
Old 01-11-17, 11:23 AM
Received 2,712 Likes on 2,297 Posts
What car do you have? I would avoid Cardone, FEQ is good Empire is decent.
Old 01-11-17, 01:20 PM
jaredmac11
jaredmac11's Avatar
I swear I forget to say that every time. 97 ES300. I'll research your suggestions. Thanks
Old 01-11-17, 11:10 PM
80es300
80es300's Avatar
If you already don't know, toyota sells re-manufactured cv shafts and many people say those are very good. I have seen online prices around $125 once you return the core.
Old 01-11-17, 11:29 PM
Last I heard the remans you get from Toyota are made by Detroit Axle, made in China and possibly U.S. parts. I'd be interested to know if anyone here has installed them. A new axle from Toyota is a small fortune.
Old 01-12-17, 10:45 AM
surgeon0
surgeon0's Avatar
I would stay away from Cardone. NAPA line premium ones are good. If you do get Cardone, NAPA also has them if you want to get locally. Other than OEM (new or reman), NAPA would be my only other choice.
Old 01-14-17, 07:50 AM
satiger
satiger's Avatar
I had a bad experience with NAPA CV axle. During an oil change found its leaking, didn't want to wait so went with remanufactured NAPA for $80 or $90. Six months later, its started leaking. Ironically that was the first non OEM part I used in ES.
Found a new CV axle sold by ConcordLexus in Amazon for $163 and purchased and replaced leaking NAPA one. I don't see that ConcordLexus part any longer in Amazon but here is the link , not sure it fits 97 models: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
LeX2K (01-14-17)
Old 01-14-17, 09:23 AM
^^ That's the way to go worth the extra money. According to this fits 1997-2001
Old 01-14-17, 03:25 PM
80es300
80es300's Avatar
Try your local dealer also. In the RX forum, a user recently posted that his local mechanic charged $200 for toyota re-manufactured axle and labor.
Old 01-14-17, 05:19 PM
surgeon0
surgeon0's Avatar
^^^ Thats the way to go. Difference between any aftermarket vs oem for +50-75 is worth it. You might get one from somewhere thinking you will save close to 100 but any oem is worth the extra cost and less headaches.
Old 01-16-17, 04:38 AM
jaredmac11
jaredmac11's Avatar
It's really hard to bite on $400 worth of parts on a car that wouldnt fetch $2000 from an insurance claim or craigslist, but at the end of the day, if these off-brand CVs dont last a year...
Old 01-16-17, 07:53 AM
hypervish
hypervish's Avatar
I understand your point. I was in the same boat, so i went with a FEQ Axle at 218,000 miles. I'm now at 242,000 miles and haven't had any issues...yet...
Old 01-23-17, 06:05 AM
jaredmac11
jaredmac11's Avatar
I got a shaft seal just in case the ones coming out are worn. Do I have to pump any leaking trans oil back in, or can I just fill it from the top?
Should I consider anything else? It seems like a straight forward job. Wish I did this when I was doing the ball joints! Then again, I'll be saying the same thing when I get to suspension...
rankone
23
08-13-14 02:55 PM
RXGS
04-02-10 09:29 PM
shikokaon
08-20-07 06:07 PM
Davtown
02-16-05 08:38 PM
Quick Reply: Recommendation on CV Shaft?
