04 ultra ls430 Front parking lights not working
Old 01-08-17, 05:36 PM
truongsean
truongsean's Avatar
Default 04 ultra ls430 Front parking lights not working
Hi,
I recently purchase a 2004 LS430 Ultra package. I noticed that my front parking lights do NOT turn on... only the back is on.
On the light switch, I turn to the first click. It right next to the Off. I have tried with the engine running and with ACC on.
Any suggestion on how to fix it would be great. I have check all the fuse and they are all good.
thanks,
Sean
Old 01-08-17, 07:56 PM
5t341th
5t341th's Avatar
the daytime running lights? they only work when you are driving
Old 01-12-17, 11:37 AM
truongsean
truongsean's Avatar
Yes the DRL does work which share the same bulb with the High beam.
Old 01-12-17, 12:20 PM
jimbosr1
jimbosr1's Avatar
are you talking about the amber lights in the headlight housing?
Old 02-22-17, 09:46 PM
russola73
russola73's Avatar
What is that little amber bulb? Can I replace it with an LED ?
Old 02-23-17, 09:04 PM
aypues
aypues's Avatar
Those are the side marker lights in amber. The bulbs go bad eventually. I had mine replaced last year. I actually replaced all the bulbs in the headlight assemblies...there are 4 per side. 1 xenon low beam, 1 daytime running light/high beam dual purpose bulb, 1 clearance lamp (the little bulb close to daytime running/high beam that keeps it lit up at night), and 1 side marker lamp. I left the fog lights alone.
Old 02-24-17, 06:56 AM
truongsean
truongsean's Avatar
thanks aypues... I did try to replace the bulbs as well and no luck.
Old 02-24-17, 01:08 PM
aypues
aypues's Avatar
so you were able to replace the bulbs or just tried to and failed? I would just pay someone to do it.
or maybe it's a fuse?
TTechLexus
01-20-12 04:19 PM
mugenh22a4
IS F (2008-2014)
10-31-10 12:22 PM
ima do me
02-08-09 12:53 PM
GS526
12-13-06 11:03 AM
Presario
06-14-01 02:15 PM
Quick Reply: 04 ultra ls430 Front parking lights not working
