2006 LEXUS GS300 RWD Transmission replacement
Hey guys, Im new here and in the market for a new transmission for my 06 gs300. Unfortunately, the trans wont shift past 3rd gear anymore.My trusted mechanic told me that getting a new one is the best solution. I have been looking around and the used trans I found were $1800>. That's insane!!! AWD trans go for 50% less easily. However I did some digging and found transmissions that share very similar Serial numbers.
The dysfunctional one I have currently in my lex (Serial #: 35010 30A60) is confirmed by the dealer that it is the US market 6 speed A/T transmission,
All of these that I found on Ebay for $1800 that has a Serial #: 35010 30A70.
Another one, a JDM trans for a lot cheaper with a Serial#: 35010 30A80 that came attached to a toyota crown 3GR-FSE engine, which happens to be the same engine in my GS!
These transmissions are all RWD so can anyone confirm if the 30A80 trans can fit my 2006 lexus gs300 without complications? What is the difference between these 3 different serial numbers?
Thanks,
Andrew S.
Thanks,
Andrew S.
I was told that it isnt a typical rebuild. I need new gear shift solenoids. 3 of them that supposedly would run me $1500 for the whole repair including labor.
I would be looking at a $1000 budget with that JDM trans.
Jdm tranny
hey guys, im new here and in the market for a new transmission for my 06 gs300. Unfortunately, the trans wont shift past 3rd gear anymore.my trusted mechanic told me that getting a new one is the best solution. I have been looking around and the used trans i found were $1800>. That's insane!!! Awd trans go for 50% less easily. However i did some digging and found transmissions that share very similar serial numbers.
The dysfunctional one i have currently in my lex (serial #: 35010 30a60) is confirmed by the dealer that it is the us market 6 speed a/t transmission,
all of these that i found on ebay for $1800 that has a serial #: 35010 30a70.
another one, a jdm trans for a lot cheaper with a serial#: 35010 30a80 that came attached to a toyota crown 3gr-fse engine, which happens to be the same engine in my gs!
These transmissions are all rwd so can anyone confirm if the 30a80 trans can fit my 2006 lexus gs300 without complications? What is the difference between these 3 different serial numbers?
Thanks,
andrew s.
Thanks,
andrew s.
...your mechanic told you that you need a new trans because of bad shift solenoids?
FIND A NEW MECHANIC!
Shift solenoids are cheap and easy to replace... drain the fluid... pull the pan... replace the solenoids... reinstall pan... re-fill with fluid. You don't even have to pull the transmission for the repair. Whom ever told you that you need to replace your transmission due to failed shift solenoids.. then quoted you $1500 for the repair... they are smoking some good stuff.
A couple hundred bucks in parts... an afternoon in the driveway.
If it is indeed a shift solenoid, it should have thrown a code for it. Verify that is the problem and fix it.
Teo4k (11-06-23)
Not to get off topic... but....
It's been a fun project. Compound turbo system (hx30/hx35 @ 40psi)... water meth injection... built 4l80e trans.... 2500hd core support, radiator, intercooler... etc..etc..etc... Been tinkering with it for a good while. Needs head studs and more fuel as the turbo system is capable of 70+psi which would put me in the 375hp/700ft.lb range.
Anyways...
Anyways...
The boots aren't standard silicone... they are aramid reinforced with a working pressure of 50psi (200psi burst strength at 500F working temp) for the big ones.. 100psi working pressure for the smaller ones. I blew through 6 standard boots in no time.. that's when I ordered these from www.verociousmotorsports.com At the time, they were the only company selling Aramid reinforced boots (which is needed for the heat. Temp coming out of the high pressure charger is over 350F and it was melting the nylon boots.
sanjaygb
03-10-15 09:27 PM
NAZTY97
08-03-11 03:24 PM
