Temperature Unit Conversion
Old 12-07-16, 07:54 PM
ahothi
ahothi's Avatar
Default Temperature Unit Conversion
I recently got a 2016 Lexus IS300 imported from Canada and was wondering is there a way to change the temperature units from celsius to fahrenheit. Thank You!
Old 12-07-16, 08:14 PM
JDR76
JDR76's Avatar
I recall that it can be changed through Carista but otherwise I think the dealer has to do it.
Old 12-07-16, 09:52 PM
ahothi
ahothi's Avatar
Okay, don't know much about carista, probably will just take it to the dealer.
Old 12-07-16, 11:45 PM
Carista
Former Sponsor
Carista's Avatar
I believe the temperature unit is not configurable in that car, but I might be wrong. I also depends on the market and specific model. Just to give you some more context on Carista, it's a mobile app with which you can change your "dealer-only" settings straight from your smartphone or tablet (Android or iPhone/iPad). All you need is the app and a hardware dongle (OBD adapter) that plugs into the car's diagnostic port under the dash and communicates with the app wirelessly. More info at www.caristaapp.com
Here's a sample list of customizations you can make to the 3rd-gen Lexus IS (based on a sample from another customer; your settings may vary):
http://www.caristaapp.com/vehicle/Le...d%20IS-C)/2016
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
YES / NO
Beep when locking/unlocking with remote
YES / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / MAX
Beep when opening/closing windows with remote
YES / NO
Warn (beep) when door can't be locked because it's still open
YES / NO
Warn (beep) when a window is still open when locking doors
YES / NO
Warn (beep) when sunroof is still open when locking doors
YES / NO
Panic function on remote
ENABLED / DISABLED
Open trunk lid with remote
SINGLE CLICK / DOUBLE CLICK / LONG PRESS / VERY LONG PRESS / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
YES / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Auto-lock all doors
DISABLED / WHEN SHIFTING INTO GEAR / WHEN VEHICLE STARTS MOVING
Auto-unlock all doors
DISABLED / WHEN SHIFTING INTO PARK (P) / WHEN DRIVER'S DOOR IS OPENED
Unlock trunk when doors are unlocked
ON / OFF
After locking with smart key, don't allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT SEATS / ANYWHERE IN VEHICLE
Unlock trunk when smart key in range
YES / NO
Open windows and sunroof by holding key in door lock
ON / OFF
Close windows and sunroof by holding key in door lock
ON / OFF
Open windows and sunroof via long-press on remote
ON / OFF
Lower passenger-side mirror when in reverse gear (req. memory seats)
DEFAULT / USER-SPECIFIED
Instruments / Display / Dings:
Engine start indicator
ON / OFF
Remote low battery warning
ON / OFF
Lights:
Daytime running lights
ON / OFF
Coming-home lights duration
OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
Turn on marker lights when vehicle is unlocked via remote
ON / OFF
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / 15 SECONDS / 30 SECONDS
Turn on interior lights when you shut off engine
YES / NO
Turn on interior lights when you unlock doors
YES / NO
Turn on interior lights when smart key in range
YES / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
YES / NO
Turn on exterior footlight (on side mirror) when smart key in range
YES / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
YES / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / 15 SECONDS / 30 SECONDS
Interior lights linked to footlight
YES / NO
Interior light control
ENABLED / DISABLED
Exterior light control
ENABLED / DISABLED
Heater & A/C:
A/C power
AUTOMATIC / FULL POWER
A/C ECO mode
ENABLED / DISABLED
Auto-increase blower speed when front defroster is on
YES / NO
Auto-turn on A/C when AUTO button pressed (if needed)
YES / NO
Deactivate front defroster when AUTO button pressed
YES / NO
Also blow to feet in "face" mode
YES / NO
Seat heater mode
AUTOMATIC / MANUAL
Fan speed reaches its target…
SLOWLY / NORMALLY / FAST
Other:
Roll down rear shade when in reverse gear
YES / NO
Delay for rolling down rear shade when in reverse gear
IMMEDIATE / 0.7 SECONDS / 0.9 SECONDS / 1.2 SECONDS
Old 12-08-16, 07:05 AM
Crossxup11
Crossxup11's Avatar
You Americans and your crazy units :P
Congrats on the car! You'll love it, I'm sure.
Old 12-08-16, 06:54 PM
Sango
Sango's Avatar
Keep the metric system, don't convert!
On a real note, Jeff Lange (the moderator), has mentioned that the temperature unit is not changeable because it is part of the HVAC system if I recall. It will essentially will need to be replaced a US one which will likely cost an arm and a leg.
Old 12-09-16, 07:02 AM
JDR76
JDR76's Avatar
That's surprising to me. I was just making changes with Carista on my parent's RAV4 and saw that in there as an option, so I assumed it was the same with the IS. Sorry for my incorrect information.
Old 12-09-16, 02:56 PM
Sango
Sango's Avatar
Yeah, I would agree that it should be an option on all cars since it is something simple. Even I wonder why it is not on all cars.
Old 12-23-16, 07:11 PM
ahothi
ahothi's Avatar
Thanks for the help guys!
foreste1
05-17-17 01:37 PM
kauaian
10-07-16 04:39 AM
Carista
Club Lexus Vendor Marketplace
03-23-15 10:48 PM
02msmg3
09-23-14 12:31 PM
pep71
03-05-14 09:46 AM
Quick Reply: Temperature Unit Conversion
