Opt7 LED Clearance Issue IS250
Old 12-06-16, 07:04 AM
Drpower
Drpower's Avatar
Default Opt7 LED Clearance Issue IS250
I recently purchased a set of low beam h11 opt7 led, but I ran into some clearance issues. The base of the bulb is rubbing against the inside metal part of the headlight housing. Does anyone had any issues with this and if you did, any solutions to this problem?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 12-06-16, 12:27 PM
ewingli
ewingli's Avatar
Installed a similar LED setup last week, didn't have problems with the bulbs rubbing. Did you also stuff everything in the housing?
Old 12-07-16, 06:14 AM
Drpower
Drpower's Avatar
Yeah, putting the stuff in the housing is not a problem. Everything fits. It just i can't screw in the bulb because of the metal base of the bulb is rubbing with the inner metal part of the housing. So the bulb doesn't twist while is in and I can't secure it. Also, did you do the install on your fog lights?
Old 12-07-16, 06:35 AM
Trolling55
Trolling55's Avatar
Are you converting your HID to LED?
Old 12-07-16, 07:16 AM
Drpower
Drpower's Avatar
No, my car didn't come with HID's
Old 12-07-16, 07:55 AM
ewingli
ewingli's Avatar
Hey I had the same problem with one of the bulb and fixed it by removing the excessive plastic near the housing as seen below:
Old 12-07-16, 08:16 AM
Drpower
Drpower's Avatar
Ok I see, but is it going to screw in and be secure?
Because it's rubbing with this metal piece
Old 12-07-16, 08:25 AM
ewingli
ewingli's Avatar
yes mine rubbed against it, and found out the excessive plastic near the housing was causing it not to be seated in properly causing the rubbing. It took me a good 20mins to figure it out lol.
Edited:
Sorry read too fast, mine LED set didn't have that metal budge so I don't know if that will stop it from rubbing.
Old 12-07-16, 08:50 AM
Drpower
Drpower's Avatar
Edited:
Lol no worries. Thanks for the help anyways
Old 12-08-16, 12:36 PM
Drpower
Drpower's Avatar
I might have to return them and get different ones. I don't want to shave off the piece of metal off the headlight. Any suggestions to this or any other brand that I should buy?
westwest
IS - 1st Gen (2001-2005)
04-05-18 08:53 AM
boobobo
01-20-17 11:55 AM
reyoasian
05-02-12 11:19 PM
RC51TOFUMA
01-19-10 01:25 PM
sputniknyc
Lighting
03-09-06 05:31 PM
Quick Reply: Opt7 LED Clearance Issue IS250
