Brake rotor and brake pad for is200t f sport
Old 12-03-16, 03:20 AM
sypw
sypw's Avatar
Default Brake rotor and brake pad for is200t f sport
I m looking for aftermarket brake rotor and brake pad for is200t f sport for street use .
Any recommendation on what brand to use?
Thanks in advance
Old 12-03-16, 09:49 AM
CriMe
CriMe's Avatar
My front brakes started squealing horribly upon initial application at only 13k on my 16 350 Fsport... I also have mild pulsation in the pedal when braking from a high speed. Took it to Lexus and they said my pads are still good and that the squealing is normal with the f-sports models. I found that to be ridiculous. the noise is obnoxious and embarrassing.
last night, I ordered Stoptech drilled rotors for the front and rear, with akebono pads. I'll be installing them myself. total from rockauto was only $460 with shipping, which is pretty good - surely better than what i would have paid at Lexus. I will get you the exact model numbers later because, from what i have gathered, the brakes in the 200t f-sport models are the same as the 350 f-sport.
Edit: These are the parts that I chose:
2016 LEXUS IS350 3.5L V6
AKEBONO ACT1118 Brake Pad [front] $ 47.79
AKEBONO ACT1391 Brake Pad [rear] $45.79
CENTRIC 12844189L (128.44189L) Rotor $ 79.89
CENTRIC 12844189R (128.44189R) Rotor $ 79.89
CENTRIC12844138L (128.44138L) Rotor $ 97.79
CENTRIC12844137R (128.44137R) Rotor $ 97.79
Discount$ -22.45
Shipping Ground $35.97
Order Total$ 462.46
EDIT / UPDATE 9/2017
For those of you who may come across this post in a search, the 128.44138L and 128.44137R rotors will NOT fit your vehicle if you have AWD. The correct part numbers for the IS350 AWD F-SPORT vehicles are 128.44184L and 128.44185R
Old 12-03-16, 10:00 PM
sypw
sypw's Avatar
Thanks for the info
Old 11-14-19, 09:30 AM
daver412
daver412's Avatar
Any update on the difference you’ve noticed from stock?
Dust, life span, noise?
Old 11-15-19, 10:46 AM
E46CT
E46CT's Avatar
Received 2,078 Likes on 1,569 Posts
I recommend:
Meyle blank rotors (due to price)
Professional stock OE F Sport pads
No free rides.
Want performance? Low life and high noise/dust.
Want low noise/dust w/ high life? No performance.
Cannot choose both.
Your call
HiPSI
06-07-19 11:58 AM
Joeb427
04-26-17 06:35 PM
tlbryant7
01-15-17 11:27 AM
khizr23
04-26-16 01:28 PM
IS350atWOT
Suspension and Brakes
02-18-10 11:33 AM
Quick Reply: Brake rotor and brake pad for is200t f sport
