HUD Display Options
HUD Display Options
Just wondering if I misread or if I am missing something, but according to the quick start guide/owners manual it says the HUD can display about 10 different things including: Tachometer, gear shift, Dynamic Radar and several other things. I have not been able to get these to display on the HUD at all. I've only gotten speed and speed limit, volume change for audio and GPS turns.
Is there a trick or setting to get these other items to display? Its page 23 in the quick start guide book.
Thanks!
Thanks!
VQboodah (08-04-21)
Tech Info Resource
Hth
This answers a few questions about the HUD. It is also possible to move the display using Techstream if you are unable to see the display well (I have this issue.)
The following 5 users liked this post by lobuxracer:
Afrosheen (12-06-16),
designo (11-05-18),
RC51TOFUMA (12-05-16),
shenry500 (09-10-18),
texaslexii (09-13-18)
In the PDF, it says to access the HUD Customization you have to hold the display for approximately 1.5 Minutes or longer to enter the custom options. So I held it for a little longer than the time suggested and nothing seemed to change so I pressed the DISP again for approx 3 seconds until the toggle for the audio came up and then I released and then the gear position disapeared and I pressed it once more and it displayed the RPM meter. I was doing this in my garage so I did not drive around to see if it changed by going in to S+ but I did get it to change.
Once again, thank you Lobux for the PDF, I think the longest I held the DISP prior to that to try to access the menu was only like 20 seconds. LOL
Thank YOU Lobux for the PDF. I got it to change the display.
I realize old thread but I have to comment as I'm trying to get more out of the HUD. Holding the disp button for several minutes does nothing for me. My only options are audio or Navi . I would live to see the tach and or gear on the HUD. The manual says it will do it. Anyone know how??
Hope this helps.
It got me too. You have to disable Lane Departure Warning in order to be able to see the tachometer. If you keep Lane Departure Warning enabled, all you get is the speedometer, navigation prompts (if enabled), speed limit (when detected/recognized), and audio information (if enabled). With Lane Departure Warning disabled, the HUD drops the lane markers and will show the tachometer that can be customized.
Hope this helps.
Hope this helps.
Thanks for the PDF bud. You can move the HUD yourself vertically, but can it be moved horizontally? I'd like to move it a little more to my right.
Tech Info Resource
That's what you need Techstream to do. I normally have a subscription to TIS that includes Techstream because I service all my cars myself. I have a laptop I bought just for Techstream and TIS, and bought the Mongoose Pro BT OBDII cable. It works like magic.
Thanks!
Tech Info Resource
If you get Techstream, you have to purchase the whole year. There is no short term option for the professional subscription. Wish it weren't so, believe me!
texaslexii (09-18-18)
Tech Info Resource
I just renewed my professional subscription. Lo and behold, they have a two day option for $65. Bad news is, they jacked up the professional subscription to $1295 annually. Ouch. Still saves me money though.
