1993 sc400 Hesitating acceleration
Old 11-29-16, 09:11 PM
93sc400nm
93sc400nm's Avatar
Default 1993 sc400 Hesitating acceleration
Still trying to get this car running right that I bought recently. I sent the ecu out to Tanin and I trust there work since thats what they do so I have to figure out whats wrong...could use some input from you helpful folks.
I have hesitation beginning just before 1500 rpm and it continues throughout the whole rpm range. At times the engine will buck harshly and falls on its face while driving during acceleration. I know its not the ecu...Cap and rotor look great, the wires look fine, someone replaced them before.
What are some more things I should check? Local people who Ive talked to say the timing belt could have jumped a tooth...how common is this?
* guess what I am looking for is input from common problems for these cars...I have no CEL and ECU is verified and tested good.
Thank You all
Old 11-29-16, 11:11 PM
t2d2
t2d2's Avatar
In my experience, that's due to failing ignition coils. Mine was centered around 1400 RPM and didn't extend all the way up from there, though.
Old 11-30-16, 05:36 PM
93sc400nm
93sc400nm's Avatar
Thanks for your input t2d2, I was considering changing those too...
I guess its time to just start throwing new parts at it and see whats going on
Old 11-30-16, 05:50 PM
93sc400nm
93sc400nm's Avatar
both ignition coils are the same part number right? Too cold to go outside and check haha
Old 11-30-16, 08:39 PM
t2d2
t2d2's Avatar
Yeah, they're interchangeable.
Old 11-30-16, 08:51 PM
93sc400nm
93sc400nm's Avatar
Ok thanks I ll order some tonight
Old 12-03-16, 04:29 PM
93sc400nm
93sc400nm's Avatar
Default Update
I drove the car around tonight and magically the hesitation is only at 1400 to 1500 rpm instead of all the way through the powerband...I think the ecu just needed time to relearn things.
Now I have a whining belt noise! Could this be due to the cold or bad timing belt? idler or tensioner?
Anyone have a whining belt before? I think its just time to put a fresh belt and tensioner on this car.
Old 12-03-16, 04:31 PM
93sc400nm
93sc400nm's Avatar
Still havent gotten the ignition coils but I hope it fixes my little hesitation at 1400 and 1500
Old 12-03-16, 11:36 PM
t2d2
t2d2's Avatar
Coils sounds increasingly likely with the updated symptoms.
Old 12-04-16, 01:23 PM
93sc400nm
93sc400nm's Avatar
Ithink it is the coils which is good because we want that to be the problem, thanks t2d2 Ill let you know how the fix goes once I get coils
Old 12-05-16, 08:03 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
If it is one of the two ignition coils, the vehicle should sound like a 4 cylinder, and drive like a semi. (go 90 down the hill to make it up the next at 60..) personal experience
Old 12-05-16, 11:18 PM
t2d2
t2d2's Avatar
If it's failed, yes, but probably not if it's failing.
93sc400nm (12-06-16)
Old 12-06-16, 05:44 PM
93sc400nm
93sc400nm's Avatar
Default Update again
Another update...this car has been sitting for a few years and its old so one thing will break after the next for a while. Has 133,000 for its age that is great I think.
Weird belt noise was actually my power steering pump...return not sender was leaking...waiting on replacement hose. However, I would like to mention that Prestone power steering with stop leak has for the time completely stopped the leak so I highly recommend, surprised it worked.
Coils will be here tomorrow
New problem, the e brake indicator light is turning on at times during acceleration...is this a signal the car is telling me something is wrong? Would this be my brake pad is low indicator or is that a separate light? ...or something else entirely? Thanks for the help, particularly t2d2 for continued help I give you a thanks
Old 12-06-16, 08:35 PM
t2d2
t2d2's Avatar
I've never dealt with the e-brake warning light coming on, but I would assume it's either a mechanical or electrical thing. If it's mechanical, you would surely notice it dragging. If it's electrical, it could be a gauge cluster issue, but is more likely the sensor on the e-brake handle itself.
I'm not sure how to troubleshoot that, but there's a little 1-wire sensor that screws to the front lower portion of the e-brake handle's base. I suppose it could be as simple as something got on or around it and is enough to make the sensor think the handle is raised (no contact between sensor and handle), or it could be a break in the wire.
If it is a faulty wire, there's a junction not far down the line, so maybe you can replace the sensor without any rewiring difficulty.
We don't have a brake pad wear indicator that I know of. The LS400 does and that sensor gets discarded when installed on SCs.
Old 12-06-16, 09:10 PM
93sc400nm
93sc400nm's Avatar
Ok good to know, I will check this out tomorrow and check for the possible mechanical issue that makes sense...there definately is no contact with the e brake and i could see how the little bit of acceleration force might turn and indicator on...i will send the cluster to Tanin down the road because I do have the faulty flashing needle and half of the gauge is lit up.
Quick Reply: 1993 sc400 Hesitating acceleration
