IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Wheel Size Help
Old 10-27-16, 01:05 AM
SRTISF
SRTISF's Avatar
Default Wheel Size Help
I have been trying to figure out what the size and offset to go with. Been trying for about 2 hours now and keep going in circles.
I want a staggered, NON Stretched, minimum camber -3 in the rear would be as much as I want, flush look if possible.
I don't care about sizes much, I just need as much rubber in the back as I can get. (thats what she said)
I can roll the fenders and modify the wells a bit if needed. Also have adjustable BC coils too. It is not slammed either, just want it lower and not rubbing. The wheels im looking at are MB Battles
I was thinking this:
R 265-35-18 with a 9.5" wheel with a +23 offset
F 245-35-18 with a 8" wheel with a +30 offset
Old 10-27-16, 11:15 AM
Golden95SC
Golden95SC's Avatar
I would stay away from lower offsets.
for a clean fitment stick to +38 maximum.
9.5 should fit with a 265 but I doubt with a +23 offset. Ul have to certainly do fender work and some camber might be needed.
You should be good with those size wheels and tires. But I recommend +38 max offset all around.
Old 10-27-16, 01:17 PM
SRTISF
SRTISF's Avatar
I can get the wheels in 9"x38 offset.. I could probably get a 265 on a 9" wheel and also get a 245 on the same?
Old 10-27-16, 01:26 PM
vividracing
Former Sponsor
vividracing's Avatar
This is a really helpful tool in actually getting to SEE what you like on a car, with all the specs laid out for you very clearly. When looking at the list, click on the "ID" link that is all the way on the far left of the list, so you can see all the pictures, and scroll down to the notes so you can see what suspension modifications have been done (rolling or pulling fenders, spacers, ect). Let me know if you need some help getting a set of wheel. Currently, we are having a huge annual sale on our JDM wheels (Volk, Advan, Gramlights), that will save you about double the normal discount.
http://rimtuck.com/search/datasheet&...01&yearto=2005
Old 10-27-16, 01:34 PM
Golden95SC
Golden95SC's Avatar
Yes a 265 on a 9" is perfectly fine.
Old 11-10-16, 07:28 PM
SRTISF
SRTISF's Avatar
So, I went with a 275/35/18 and 9" with +38 offset for the rears, it fits without to much issue, need to roll the fenders a tad.
The front is a 225/40/18 with a +43 offset, it is pretty flush looking. The tire sticks out of the fender about 5/8" but nothing that a little roll and pull cant fix. Either way, I am happy with the set up since I have 10" of meat in the back.
Old 11-13-16, 10:16 AM
Golden95SC
Golden95SC's Avatar
Yea a small rolling is usually always needed. Good choices in the fitment!
Old 11-13-16, 10:40 AM
SRTISF
SRTISF's Avatar
Getting them rolled today. I adjusted the coils a bit. After
After
Before
Before
Before
Old 11-13-16, 03:26 PM
SRTISF
SRTISF's Avatar
Originally Posted by kitabel
Sorry, when you suggest that camber adjustment is a tool to fit a larger wheel I lose interest.
Do some reading on the effect of reducing the tread contact area on handling - it's all bad.
I don't need to do any reading. Look at what the ISF runs, or M3 or a Koenig. -2.5 is pretty standard.. I'm running -2 and have full tread contact. Why else would you want a larger wheel? For more tread contact.
Old 11-13-16, 09:38 PM
Golden95SC
Golden95SC's Avatar
Wheels look great. Did you drop the car or raise it km the pics?
Old 11-13-16, 10:05 PM
SRTISF
SRTISF's Avatar
Thanks! I labled them before and after. I dropped the front 3/4" and lifted the back 1/2". So it is level now. I also rolled and pulled the fenders too so it doesnt rub for the most part.. I need to adjust 1 more coil on the driver front because it rubs if I corner super hard.
Old 06-12-23, 03:51 AM
PGARazor
PGARazor's Avatar
Default Fitment Question for GS F
Looking to upgrade wheels on 2016 GS F. Question is will I be good with a new front wheel of 19X10 ET 35, rear 19X11 ET 50 without rubbing. Thanks for input
Old 06-12-23, 11:35 PM
2001SolarY
2001SolarY's Avatar
Wrong forum. The is for the 2001 to 2005 IS model.
Andyb63
05-06-15 12:45 AM
802lexus
03-18-12 10:17 PM
Yamaheart
11-03-10 01:41 PM
Sceptre
03-27-07 09:20 AM
indypwr
GS - 1st Gen (1993-1997)
07-13-06 03:13 PM
Quick Reply: Wheel Size Help
