Sc300 treadstone nat manifold fitment?
Hows it going guys. Im planning on going nat with my 95 sc300. And im trying to figure out exactly what I'm looking to do. The ultimate goal is 500-600 on pump and room to grow on e85.
The treadstone manifold will be my best option for clearance with the throttle body. But the issue is im not sure exactly "how much" room between the chassis and the manifold itself.
I've looked for reference picks but can't find much. Most people run a .68 ar from what I'm able to find.
The bw s360 is on mind but the smallest ar on the hotside is a .88ar. is anyone aware if that size ar housing wil fit properly in a sc300?
I would use a standard manifold but I can't find anywere that sells a intake manifold spacer to give some clearance.
Lmk thanks
Lmk thanks
Hi Gerrb!!
You would be the person to ask this, what numbers will ar67 cold and .81 hot should I expect with the right fuel mods and TT hg, arp stds q45 tb. Will golden sc reach his power goal with the similar setup on let's say Jdm ecu vvti could
sorry off topic here, but op could use this info since we have a very similar power goal
NYCsc300 (01-21-21)
The Borg turbo will hit the shock tower. I'd recommend a Precision unit.
Steve K.
Steve K.
Hi Gerrb!!
In choosing a turbo , choose the smallest turbo with the smallest turbine a/r that will handle your power goal so you can have the best spooling setup !
Thanks Gerrb!!!
Golden: the 90 degree elbow spacer would have to be custom fabricated using 2 t4 ( or whatever) flanges and an elbow. By looking at the pic you're limited to how big of a compressor you can use, and with a short elbow, you'll be able to relocate your turbo up a little because you have plenty of space between tb and the housing itself.
thats the only way you can run a bigger compressor.
im surprised you don't want to go with tubular manifold instead, which is a lot more cost effective route...
I'm using one of these on an IS300 2JZGE motor in an IS300 chassis and it fits just fine w/ a BW EFR 6758. It even has an adapter to go from T4 to v-band on the collector and still clears everything just fine.
NYCsc300 (07-17-21)
HiPSI
Performance & Maintenance
61
04-16-15 12:49 AM
933005spd
SC400 / 300 Classifieds
06-06-07 06:25 PM
