Square 18x8 48mm+ - Is offset okay?
Old 10-26-16, 10:42 AM
FWizard
FWizard's Avatar
Default Square 18x8 48mm+ - Is offset okay?
Hello, looking at some Looking at a deal on some OZ Ultraleggera rims for a winter setup.
Does square 18x8 48mm+ work on our cars? Wondering if you would hit the strut or shocks with such a +48mm offset
Old 10-26-16, 11:03 AM
bnizzle87
bnizzle87's Avatar
Offsets will be more than fine. As reference, a few guys and myself are running 18x9.5 et 40-45 with zero clearance issue. What tire size were you considering?
Old 10-26-16, 03:03 PM
jspecvtec
jspecvtec's Avatar
Those offsets r extra conservative. Even more so or close stock
Old 10-26-16, 03:09 PM
FWizard
FWizard's Avatar
Thanks guys, forgot to mention they will be with 225/45/18 rubber
and the car is stick ride height
Old 10-26-16, 06:05 PM
jspecvtec
jspecvtec's Avatar
Originally Posted by FWizard
Thanks guys, forgot to mention they will be with 225/45/18 rubber and the car is stick ride height
225 on all corners? That's super narrow. Is this for an isf?
Old 10-26-16, 06:10 PM
ISFLexy
ISFLexy's Avatar
I would think you want super narrow for a winter setup. Carves easier through snow.
Old 10-26-16, 08:41 PM
jspecvtec
jspecvtec's Avatar
Oh winter setup, didn't read that
Old 10-26-16, 09:38 PM
FWizard
FWizard's Avatar
Yes winter with some Blizzaks W80. It gets kinda wobbly when accelerating hard and at higher speeds a bit unstable at times, but whose gunning it on public roads with snow on the ground...
Old 10-26-16, 10:00 PM
blackisF08
blackisF08's Avatar
those are some expensive wheels to be using during winter though, tires are fine. i run 225/45/18 all around for winter
Old 10-26-16, 11:34 PM
jspecvtec
jspecvtec's Avatar
Haha sorry, I live in SoCal so i don't know what winter is lol
Old 10-27-16, 08:51 AM
BLKLBL
BLKLBL's Avatar
with VSC and TRAC off, the ISF is a blast in the snow. I'm on winter #3 with the ISF as a daily driver. I also run 225/45/18 on 18x8 wheels,, I think the offset is a little lower on mine tho, possibly +45.
Old 10-27-16, 10:20 AM
blackisF08
blackisF08's Avatar
one thing i envy from california is the weather but dislike everything else lol anyways back on topic. my wheels are 18x8 40+ and they work fine. i also take traction control as it is a little intrusive when it loses traction but not as bad as my old is300 used to be. overall the car handles really well in snow.
does any one have this issue in snow when you come to a complete stop and the car moves a little bit forward?
Old 10-27-16, 06:05 PM
ap2s2k
ap2s2k's Avatar
I run 225/45/18 in winter, they work fine, the only issue I have in winter sometimes is when the car is cold and I'm at the stop in drive , my rear wheels start to slip with the brakes on, I have to throw it in Neutral in first few minutes until car warms up and my Rpms drop a little.
Old 10-27-16, 09:27 PM
FWizard
FWizard's Avatar
You guys are so lucky, I just drove the F all the way from Calgary to LA in September and the weather was just epic
Old 10-28-16, 08:23 AM
BLKLBL
BLKLBL's Avatar
The first time I winter drove the ISF this caught me by surprise. It seems like the brake-bias is heavily biased towards the front.. so at normal brake pedal pressure the front wheels will lock up and hold the car.. but its not enough brake force to hold the torque from the rear wheels back, so the rear wheels drive thru the brakes, and skid the car forward on the front wheels.
If I go hit a drive-thru for coffee or stuck in stop n go traffic, sometimes I'll just put the car in neutral, just to make sure it doesnt skid forward.
Quick Reply: Square 18x8 48mm+ - Is offset okay?
