Squared setup - will it fit?
Old 10-23-16, 03:35 PM
flawless
flawless's Avatar
Default Squared setup - will it fit?
285/35/18 ventus v12
18x10 +43mm offset
Car is lowered on KW V3
Will they fit?
Old 10-23-16, 05:41 PM
jspecvtec
jspecvtec's Avatar
Rear should be ok rolled, not sure about the fronts.
Old 10-23-16, 05:53 PM
Gymkata
Gymkata's Avatar
The front "should" be okay as well. You will probably get some rubbing in front depending on how low you are. You may have to raise it up a bit if it rubs too much. My track setup is squared 275/35R18s on a 18x9.5 +45 wheel. My particular 275s are actually as wide as some 295s and I don't have issues in the front and am lowered on coilovers.
Old 10-24-16, 09:45 PM
SlowXIsf
SlowXIsf's Avatar
im not sure about the front with that size tire but im running 19x10 +43 sqaured fronts tires are 255/35 and rear are 275/35
Old 10-24-16, 09:57 PM
bnizzle87
bnizzle87's Avatar
I would suspect the rears fit quite nicely, and many have used that same wheel/tire sizing. The fronts, knowing that they're lowered, will probably rub slightly at full lock and even on large dips. Otherwise, I don't believe they'll rub. I've seen 19x10 up front, and there was minimal rubbing on his 275/35.
Old 10-25-16, 10:50 AM
tas02
tas02's Avatar
Keep us posted on if and how you get this (285's on the front) to work.
Old 10-25-16, 01:11 PM
flawless
flawless's Avatar
Thanks for all the input but I decided against them because the package wasn't offering a better wheel than the factory set I still have. I've been trying to justify the $$$ for different wheels, requirements include lighter and stronger for track use, but haven't been able to find something that isn't multiple thousands and I like that much better than the factory wheels.
For now, I'm going with;
factory wheels
245/275 yoko AD08r tires
15 mm HR spacers
Old 10-25-16, 07:03 PM
Gymkata
Gymkata's Avatar
Rafi from RR Racing runs 285s on all corners. You could ask him for his setup details.
Old 10-26-16, 05:04 AM
mikersoft
mikersoft's Avatar
Rafi's wheels are 19x9.5 +41 offset.
http://www.tsw.com/alloy_wheels_nurburgring.php
I'm considering those wheels for my track set-up... Or maybe the 18x9.5 version, which is a +40 offset.
-Mike
Old 10-26-16, 09:45 AM
flawless
flawless's Avatar
-Mike
I considered those TSW wheels as well, but in the end I didn't find them more appealing than the factory mesh wheel for the money spent. I think both are good looking wheels.
i2fat
06-23-15 10:35 AM
Turch
12-16-13 07:36 PM
ming15237
IS F (2008-2014)
06-06-10 06:46 PM
kingbigs11
03-11-10 09:41 PM
JohnnyIS25
08-18-08 01:12 PM
Quick Reply: Squared setup - will it fit?
