1994 ES300 will not fire
Old 10-22-16, 04:34 PM
Bistro
Bistro's Avatar
Default 1994 ES300 will not fire
Please help. Gf attempted to boost her es300 when I was not around and had cables on backwards.
After that, was getting no interior lights or reaction with booster cables connected (the right way) when I got home.
Checked and replaced a bunch of fuses. Main alternator 100A was blown. Replaced that. So was dome light and some others.
Engine now cranks and everything else seems to work but won't fire. Smells like fuel (flooded) so I assume it's not a fuel pump or injector issue.
I am guessing I am not getting spark. But I don't have the tools here to pull the plugs and check. Are there any specific relays that could be causing this? I've checked all fuses I can find in the 5 fuse boxes (both kick panels and instrument panel and 2 in engine bay). Seems like all fuses are good. Not sure about the relays. Tried swapping ones that were similar.
Is is there any specific fuses I should double check? Or any reason why it wouldn't be getting spark?
any help appreciated.
Thanks
Kub3l
06-11-16 09:52 PM
EddieKat
12
08-31-15 04:29 AM
phoenixnsx
20
01-31-15 10:22 PM
neohades
09-20-09 01:26 AM
GEes3
07-18-09 11:04 PM
Quick Reply: 1994 ES300 will not fire
