Brake Screech
Old 10-19-16, 09:18 PM
Rezno
Rezno's Avatar
Default Brake Screech
Occasionally my brakes will screech on a cold start when its cold or wet for about the first 2 or 3 times I press the pedal. Its not a big deal at all, but my guess is I should replace pads. Is there anything else I should consider or is this a common occurrence or..?
Old 10-19-16, 09:28 PM
flowrider
flowrider's Avatar
Received 1,815 Likes on 1,281 Posts
Yes, you should measure the thickness of the pad, thickness of the rotor and condition of the rotor surface. When and if you do anything, you need to know how old your fluid is and if it is due for a flush and refill.
Lou
Old 10-20-16, 08:42 AM
getafewliv
getafewliv's Avatar
Mine used to screech loudly right before I came to a complete stop. I put in the anti-squeal pads, and problem solved.
Old 10-20-16, 01:30 PM
Rezno
Rezno's Avatar
Appreciate the help from both of you. I will do all of this next time I can work on the car.
Old 10-21-16, 10:45 AM
Aspect
Aspect's Avatar
Are you on OEM pads or aftermarket ones?
Old 10-21-16, 01:40 PM
Rezno
Rezno's Avatar
OEM pads. My car is completely stock.
Old 10-21-16, 03:46 PM
Gville350
Gville350's Avatar
You probably park outside in the moist Oregon air. If you do, overnight you can get a slight layer of surface rust that builds up on your rotors. Upon the first couple uses of your brakes, you'll effectively be removing that rust with your pads causing that noise.
Old 10-22-16, 10:36 AM
Rezno
Rezno's Avatar
This is painfully accurate lol. I do my best not to park outside but because I park and ride occasionally I have to leave it outside. I didn't actually know this.
Old 10-22-16, 07:50 PM
Gville350
Gville350's Avatar
Born and raised in Tigard, OR...so I've experienced it myself.
Old 10-24-16, 07:42 PM
aventur2
aventur2's Avatar
I get the same thing every now and then. Dealership checked my brakes at my last service no issues. So maybe the moisture thing? But I live in socal so idk
Old 10-25-16, 02:47 PM
Rezno
Rezno's Avatar
That explains so much lol
Probably is. I haven't taken my car to service since I got it, but I'll probably ask about it anyway.
JDMV8
IS F (2008-2014)
31
09-29-15 09:06 PM
9000revs
01-31-15 06:14 AM
jusclark13
01-03-15 02:44 AM
GS300 I6
Maintenance
12-22-09 05:37 PM
valgs350
12-15-07 11:35 PM
Quick Reply: Brake Screech
