Build Threads Details on Club Lexus SC owner vehicles
SC400 Built to run in the desert
Old 10-17-16, 01:57 PM
jrally
jrally's Avatar
Default SC400 Built to run in the desert
Just dropping in to show the progress of my off road SC400 build. It ran as the Course Opening car at the Prescott Rally a few weeks back.
-Jon
Attached Thumbnails SC400 Built to run in the desert-fb_img_1475465959723.jpg
Old 10-17-16, 02:27 PM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
Cool! Simple and rugged. It's weird to see an SC lifted with off road tires but I like this in a rally race car. The V8 engine torque has to be great for this.
Would you care to share the modification list with us? I'm curious about your choice suspension in particular.
Old 10-17-16, 03:28 PM
Ali SC3
Ali SC3's Avatar
I dig it, maybe throw a solid axle or 2 under it and see what it can do.
Old 10-17-16, 07:00 PM
Ramblerman
Ramblerman's Avatar
Like it! We just keep on finding new uses for these old girls. Rally on!
Old 10-17-16, 07:06 PM
ThomasGS4
ThomasGS4's Avatar
This is too cool. Looking forward to seeing more pics!
Old 10-17-16, 09:40 PM
97-SC300
97-SC300's Avatar
Forget pics, I want videos of this thing. Badass.
Old 10-18-16, 08:00 AM
jrally
jrally's Avatar
So far, the mods have been fairly simple, all about making it reliable and a little tougher. Visually, it has been trimming up the skirts, who doesn't like a lady in a short skirt!! I tucked the spare tire well at an angle to give more clearance at the very tail. I then deleted the rear mufflers, in favor of straight pipe sections for a little performance and again, ground clearance. The front end was bolting on a pair of FJ Cruiser shocks with 7/8" thick spacers on top. The only mod was redrilling the top of the tower, really just slotting the 3 holes towards the center. I went ahead and reinforced the tower top with 1/8" plate and a 1/2" tall center ring while I was at it. In hind sight, I wish I had used the 7/8" spacer as an adapter ring too, converting the FJ top hat pattern to the SCs, but either way it worked out fine. For the rear, I had to make custom arms for the where the shock mounts. As an engineer and someone who's built and raced a few rally cars in the South West, I just didn't like the OEM design. So, it was made with a single heim joint at the hub side, shock mount moved to the top of the arm and the inner side reused 1/3 or so of the OEM arm, welded inside the box arm. The picture is during a test fit, not the final piece. For the shock, it currently is using a BMW 5 series rear shock and spring from the early 90's model. But, I'm building a set of rebuildable off road coil over shocks with massive 7/8" shafts to replace those soon. The guy who drove it at the rally LOVED it, couldn't stop raving about the power and smooth handling.
-Jon
Old 10-18-16, 08:35 AM
Ali SC3
Ali SC3's Avatar
wow, looks good... keep up the good work.
Old 10-18-16, 09:37 AM
CatManD3W
CatManD3W's Avatar
I have come across another off road inspired SC as well.....cant remember if it was on a facebook group or instagram....
It had oversized tires and a roof rack from what I remember
Old 10-18-16, 09:43 AM
jrally
jrally's Avatar
There is a nice, dark green Soarer in Australia that I've seen, chatted back and forth with on a FB Forum.
-Jon
Old 10-18-16, 02:19 PM
LEXXIUM
LEXXIUM's Avatar
MOre like a prerunner 4x2 light trail buggy, sc front wheels gonna get stuck in the mud, the rear will start slipping and then diggin, with your fab skills you can do the solid axle like they did in *** monkey garage
Old 10-18-16, 02:36 PM
t2d2
t2d2's Avatar
Glad I wasn't the only one struck by the coincidental timing of this thread and yesterday's K-maro episode.
Old 10-18-16, 02:40 PM
jrally
jrally's Avatar
I live in the desert SW, mud is not something I come across very often.
Besides, I've got a car like that already. (Yes, I realize the irony of the photo, after saying I don't see mud often...)
-Jon
Old 10-18-16, 07:31 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Thats awesome...
Old 10-20-16, 12:10 PM
INTIMAZY
INTIMAZY's Avatar
The rear axle idea is probably not too hard to pull off. The rear subframe is pretty bulky and leaves a nice amount of space for an axle when taken out. The LCA mounting point already exists roughly where it should. Find an ol' Mustang 8.8 for cheap and see if it fits!
Quick Reply: SC400 Built to run in the desert
