NV Megan Racing Street LP Series Coilovers - $450 Shipped
Old 10-15-16, 06:13 PM
Dxpliciton
Dxpliciton's Avatar
Default Megan Racing Street LP Series Coilovers - $450 Shipped
I am selling a set of Megan LP 32 levels of adjustment coil overs. These pictures are actual photos of the item and ready to ship to new owner. Not much to say on my side other than i am in Las Vegas, and your welcome to pick up if your not far at a bit lesser money than advertised. $450 Shipped to the lower 48 states.
The Street LP Series is our new Luxury Package, based off of our Street-Series using similar specifications and design, but offering a more conservative spring and damper setup for a more comfortable ride, yet still providing a sporty feel & control.
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts, including camber plates integrated with the upper Pillow Ball mounts on strut-type suspension applications.
Compression and rebound settings are easily adjusted through a single damper adjustment **** which is built-in at the top of the damper mount for easy access. Adjustments are simple to tune according to your style of driving and desired comfort level whether you are a professional certified mechanic or an automotive enthusiast with amateur mechanical skills. All of our dampers are capable of handling a +2kg/mm or -2kg/mm change in spring rates to further tune your suspension to your desired handling characteristics.
Height adjustments are made with separate CNC-Machined locking spring perches for accuracy and smooth adjustment with separate damper shock length adjustment to retain full-stroke and allows for precision suspension tuning. The wide range of allowable ride-height adjustment allows you to retain the factory ride-height for OEM appearance with performance handling, drop your car all the way down for an aggressive stance, or fine tune your suspension for the race-track to lowering your center of gravity to gain full potential of your vehicle's handling capabilities.
SPRING RATES:
F: 62mm ID; 220mm length; 10 kg/mm
R: 62mm ID; 200mm length; 10 kg/mm
DAMPER SPECS:
F: 140mm stroke; 290mm length; M6 valving code
R: 175mm stroke; 270mm length; A1 valving code
Features:
- Lexus GS350 2013+ RWD only
- Lower 3.5"
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
Dxpliciton is offline
Old 10-22-16, 04:27 PM
mjn88
mjn88's Avatar
How long have they been on your car?
mjn88 is offline
Old 10-25-16, 12:22 AM
Dxpliciton
Dxpliciton's Avatar
Approximately 6-7000 miles. I've had my car less than 6 months.
Old 11-23-16, 12:34 PM
Dxpliciton
Dxpliciton's Avatar
A bump for the holiday. Too many people not following through.
Old 12-08-16, 10:20 AM
Dxpliciton
Dxpliciton's Avatar
Sold, thank you.
Old 01-21-17, 07:08 PM
ArcFsport
ArcFsport's Avatar
Default coilover sale?
I know your post about the coils been up for a while but they still for sale?
ArcFsport is offline
Old 01-21-17, 07:11 PM
ArcFsport
ArcFsport's Avatar
Didnt see see the sold. Ignore me please
ccma415
05-06-16 07:52 AM
phil9892
12-26-14 12:19 PM
Heyboss2JZ
IS - 1st Gen (2001-2005)
18
08-04-12 06:55 PM
MC3 Wheels
Club Lexus Vendor Marketplace
03-22-11 11:01 AM
guillermo
08-20-09 12:17 PM
Quick Reply: NV Megan Racing Street LP Series Coilovers - $450 Shipped
