Strong smell inside 1999 Lexus ES
Recently my 1999 Lexus ES has developed a very strong interior odor. I am not aware of any water damage to the interior of the car. The carpets are all very dry. I even checked the spare tire area and it was dry also.
I cannot figure out where the smell is originating from, and I can't seem to get it to go away. It smells up my entire garage. The smell is not like the usual smell that just comes out when you initially turn on the air conditioner.
I took the vehicle to a local garage and they said it was mildew. The garage service said they checked the carpets but could not find any moisture. This issue is really puzzling me and I am not sure what to do to remove the smell.
Please let me know if anyone has had the same problem before, or if anybody has any ideas what may be creating the problem.
Thank you.
Thank you.
Yeah, check your cabin air filter. When did u last change it? These model year ES may or may not have the filter. (I believe there was some issue at that time are something like that... so some cars don't have them). So check to see if your car has one. It is by the accelerator pedal. There are threads that show how to change it.
Keep us posted if you find anything else.
Definitely check the cabin filter compartment. You may have accumulated a lot of wet leaves in there over time. Toyota sells an excellent A/C Refresher kit that I used to clean out my system.
I had an issue with mildew and/or mold within the first year of owning the car. Discovered no filter inside the compartment. Cleaned out all the crap that was in it, used the refresher kit and installed a new cabin filter. This has solved my issue.
Check out my video on how to get to the filter.
Most likely it is your filter, but if not, then check your rear tire-well area and especially the side cavities if they are separate on your car. See if the smell is stronger in the trunk and originating there.
I had an issue with water collecting and staying in the driver's side hollow below the storage tray on that side - like 2.5 gallons of it! No idea how it got in (sunroof drains were a-ok and not leaking, nor was trunk seal). Ours is a 4ES but yours is likely the same basic design.
Another thought - is your condenser drain clogged? Your car should leave a good puddle of water when parked after running the cc in "Auto" mode. If it is not, check that out. There is a lot of sound-insulating material beneath the carpets, in the doors, etc. and it can soak up a lot of water before the carpet above would ever show anything. So I in no way think that dry carpets precludes an A/C issue as the cause.
If you can smell it inside your garage as well, than I doubt that its originatging from INSIDE your car. It may be something underneath, or under the hood. A dead animal perhaps?
I agree with PFB. My first thoughts when I started reading this thread was something dead under the car. I've had a dead snake under there on an Expedition; it was really foul and took a while to find it.
I like the dead animal idea, maybe something is hiding in your garage?
I want to thank everyone for the wonderful responses and suggestions. I plan to investigate several of these suggestions. I parked the Lexus for about 5 minutes with the air conditioner on and did not notice any water beneath the vehicle. Please let me know if anyone knows how to check the air conditioner drain to see if it is clogged.
Thank you.
Thank you.
Thank you.
Thank you.
In any event, check your carpets to make sure that there is no water there. In order too see if the drain hose is plugged , you'll need to get under the car and stick a clothes hanger in the drain. It exists somewhere near the front passenger seat underneath the car.
