Help car in limp mode PO300 P0305 P0306
Old 09-30-16, 02:04 PM
cajunlexus
cajunlexus's Avatar
Default Help car in limp mode PO300 P0305 P0306
Have a 2011 ISF with 16K miles, Joe Z intake /Exhaust, Sikky headers, and RRRacing tune. The last modification was the RRRacing tune approx 6 months ago.The car has been running fine with no problems... While driving the other day for just a few minutes, I was waiting in traffic the car starts to idle rough, as the traffic started moving the car continues to pop and miss definitely not as responsive as normal, in a mile the check engine light and traction light come on and the car goes into limp mode.. the throttle response is minimal; I can only get the engine to make 1500 RPM..
Ran an OBD2 scan and came up with P0300 misfire Detected on multiple cylinders and P0305 & P0306 (misfire detected on cylinders 5&6 ) . Changed the battery because it was the original and was getting weak at start ups. Added some sea foam and fresh gas ...any thoughts as to where I can start to try and fix this problem?
Old 09-30-16, 04:08 PM
Tom2769
Tom2769's Avatar
I'm new to the ISF and haven't poked around on it mechanically yet, but in general for a car with COP coil packs: visually/physically inspect your coils and their connectors on cylinders 5 & 6. If nothing is obviously disconnected/burned/etc, try clearing the existing codes and swapping the coils from 5 & 6 with coils from 2 other cylinders (ex: swap coil #5 with coil #1, and #6 with #2, etc). Then drive the car until codes pop up again and see if you now have codes for misfires on the cylinders with the coils that were originally on #5 and #6 (in other words, misfires on cylinders #1 and #2 if you swapped them as in the example above). If the misfire follows the coils that were originally on #5 and #6, you have 2 bad coils identified - replace them with new. Or I could be completely off and there may be some known misfire issue with the ISF that I don't know about yet...
Old 09-30-16, 07:23 PM
wmjeffreyw
wmjeffreyw's Avatar
Did you have any recall work done on it recently? If so, pull the engine cover off and check all the wire connections around the intake manifold.
Old 09-30-16, 08:30 PM
cajunlexus
cajunlexus's Avatar
I haven't had any recall work done recently.. I looked under the engine cover and connections look good. Will try swap coils as Tom2769 suggested. When I searched someone had a car that he was test driving do the same thing however no fix was mentioned. I was curious if faulty O2 sensors would throw these codes?? or if the tune from RRRacing overrides the O2sensors ??
Old 09-30-16, 08:33 PM
k20trick
k20trick's Avatar
No, but a bad head from over revving can cause these codes (permanently until fixed). How high are you revving to?
Old 09-30-16, 08:52 PM
cajunlexus
cajunlexus's Avatar
I have the 7200 rev limit with the tune but honestly I do not push the car to the limits.
Old 09-30-16, 09:00 PM
k20trick
k20trick's Avatar
Oh ok cool, I dont push it above 6800 either, have done so a couple times because I was stupid but really I only use the extra rpms to prevent from bouncing off the stock 6800 limiter.
Back on topic, I was only stating the last resort facts, if your o2 sensor was faulty it would've probably thrown a o2 sensor code along with the misfire code, but you didn't express that so yeah starting at the coil packs, plugs, etc would be the right way to go.
Old 09-30-16, 09:01 PM
jspecvtec
jspecvtec's Avatar
Do u have o2 simulators on headers with rrr tune o2 delete?
Old 09-30-16, 09:44 PM
cajunlexus
cajunlexus's Avatar
I had the O2 simulators on headers when I had headers installed back in 2012. My next question would be which coil is 5 and 6 ? just took off engine cover and all the coils look similar AKA can't find one that looks a different color ..
Old 09-30-16, 09:51 PM
k20trick
k20trick's Avatar
After you installed the new battery has the code came back?
I know my car threw a weird code when battery was about to die I knew because I noticed my cranks were slow after the 3rd day it died and new battery fixed that issue.
Old 09-30-16, 09:52 PM
k20trick
k20trick's Avatar
Not sure about the firing diagram on these motors Im sure with a little research you can locate diagrams.
Old 09-30-16, 10:07 PM
flowrider
flowrider's Avatar
Received 1,835 Likes on 1,296 Posts
See attached.
Lou
Old 09-30-16, 10:12 PM
cajunlexus
cajunlexus's Avatar
Thanks Lou !
Old 09-30-16, 10:14 PM
cajunlexus
cajunlexus's Avatar
Yes installed new battery and car threw the same codes.
Old 09-30-16, 10:18 PM
k20trick
k20trick's Avatar
How soon did they come back? Instantly or after a drive out of nowhere like the first instance?
Quick Reply: Help car in limp mode PO300 P0305 P0306
